Question about Spalding 72351 Portable Basketball System with 44-Inch Polycarbonate B
Need set up instructions for a spalding basketball system 44' model # 77537T
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
Need instruction manual
http://www.instructionsmanuals.com/
Feb 14, 2016 | Spalding Basketball Spalding NBA 66349...
How do I fix a wobbly in ground basketball hoop
I would clear any loose debris, repack around pole with a dry concrete mix then add water to it make sure pole is level, brace if necessary and give 24 hours to set up.
Apr 18, 2014 | Basketball
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
How should I clean my basketball uniform?
You should wash it on a regular cycle. It does not to be gentle because the fabric can take a lot of pressure and sometimes need it. You can even put the detergent directly on certain spots to get rid of stains. I just suggest that you don't use bleach and that you use cold water so that the colors don't run.
Feb 06, 2013 | Basketball
I need a instructions on a lifetime portable basketball goal that i can praint out
Here is a link to the manual you are looking for. I found it on the manufacturer's official site.
Jan 29, 2013 | Project Runway Lifetime 48" Portable...
How to install above the rim basketball hoop system
I believe this is the product you are referring to. The link is to the item on Sears' website. You should be able to find a manual there.
Jan 28, 2013 | Basketball
Spalding 72351 Portable Basketball System with 44-Inch Polycarbonate B Logo
187 people viewed this question
Top Spalding Basketball Experts
Tom Chichester
Are you a Spalding Basketball Expert? Answer questions, earn points and help others
