Sc322 when start a copy paper remains in registration and sc322 code is shown on display
I already change and clean polygun motor but problem is still
    Welcome Back:
    Visited the website for 2 consecutive days.
First your copier model
Posted on Apr 22, 2015
TOSHIBA 455 MECHINE HANGS ON COPYING
Clean the 2 registration sensors and the registration clutch. Mostly this is caused by paper dust to the 2 registration sensors. This sensors is easily removed by opening the side cover , you'll see the registration sensors at the lower part of the drum unit. There is only 1 screw holding this. Remove that screw and slide it to remove.
Oct 27, 2014 | Toshiba OEM ESTUDIO455SE 45 PPM...
When i am switch on my mobile display has shown is SIM card registration failed
try to clean with a little water or alcohol 100% , if after this clean remain equal you must go to the dealer.The SIM will be faulty.
Dec 01, 2011 | Cell Phones
Got a function code SC322 on lanier 5622 copier. Power cleared the unit several times but status remains unchanged.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
Sep 15, 2010 | Lanier Office Equipment & Supplies
What does this code mean L6-10
change laser unit . or polygun motor.just do this
Apr 28, 2010 | Sharp AR-M450N Copier
It has an error code 322.I took out the drum unit but upon returning it gave me the error code
sc-322 is a code of laser synchronization error.just open the laser unit and clean all the mirrors and lenses carefully with a soft cotton cloth or j cloth.and also clean the polygun motor.this
Dec 07, 2009 | Ricoh Aficio 1013 Copier
Output section problem - Error code H5-01
H5-01 indicates that you have 5 continous paper jam in a row. It's generated when one of the paper feed sensors did not detect the paper, in your case the sensor might be the one that located in the exit section ( POD1 ). This photo sensor might be just covered with paper dust in between the gap housing, the gap is only 1 mm wide. You can check the functioning of this sensor by entering the sim mode 30( main code), 1(sub mode). After entering this mode try activate the sensor by moving the plastic actuator, if the POD1 display highlighted on and off it means OK. To enter the simulation mode go to the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
But first reset the error H5-01 by entering 14(main code) then 1(sub code), you might be already fix the problem.
Good luck
Apr 14, 2009 | Office Equipment & Supplies
SC322 on Ricoh Aficio 2035
forget the laser unit your developer is shot... machine cant detect vsp and vsg... therefore gives a laser error... replace developer run developer initialization in sp mode copy sp drum... should solve the problem
Feb 16, 2009 | Ricoh Aficio 1035 Copier
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
Error 77 is apprearing
Unplug the unit.
Hold down the menu key while plugging back in / powering up.
When finished initializing, hit 99.
Wait to status comes back and hit 91.
This supposedly happens due to a power surge or outage.
If this doesn't work for you try reversing the numbers above.
I have a bad memory, it might be 91 first then 99 but, you definately have to hold down the menu key.
Sep 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Toshiba e-studio161 Developer
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Apr 11, 2008 | Toshiba e-Studio 161 Copier Copier
89 people viewed this question
k24674
