Question about HP LaserJet 3030 All-In-One Printer
Scanner bulb error - HP LaserJet 3030 All-In-One Printer
    Sergeant:
  • 258 Answers
MORE INFO REQUIRED
Posted on Apr 28, 2015
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Backend optical error
check on feeder side assembly, there might loos contact on bulb or on bulb controller.
Jun 07, 2010 | Fujitsu fi-4340C Flatbed Scanner
Scanner error 52 during opening scanner bulb warming up error scanner error 52 what should i do
If you can open it, please reseat the scanner flex cable after turning the machine off. For full details on how to troubleshoot, please refer here.. Hp error code 50 - 59 Good luck. Thanks for using FixYa.
Jun 05, 2010 | HP LaserJet 3330 All-In-One Printer
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
Scanner failure
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with
the scanner hardware. Perform the following steps to resolve the error:
1. Verify that the scanner bulb is lit. If the scanner bulb will not
light up, the all-in-one will require to be serviced.
2. Perform a Power Cycle on the all-in-one as listed below:
a. Verify that the unit is switched on.
b. Remove the power cable from the back of the machine.
c. Wait for 20 seconds.
d. Reinsert the power cable in the backside of the unit.
3. If the error continues to persist, remove the power cord from any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product.
4. Cold ambient room temperatures may also cause this error. Move the all-in-one to a warmer room and see if the error reoccurs.
May 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Scanner error message hp laserjet 3030
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Jul 14, 2008 | HP LaserJet 3330 All-In-One Printer
Scanner error 6
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
Apr 22, 2008 | HP LaserJet 2840 All-In-One Printer
Scanner not working - get error message
First, check to see if the bulb lights up, if not you have bad bulb. the bulb can be ordered separately. if the bulb is good, you have a problem with the main board.
Nov 02, 2007 | Epson Perfection 1240U Flatbed Scanner
HP LaserJet 3030 All-In-One Printer Logo
Seeker5211
Seeker5211
