Question about Refrigerators
My Freezer leaks into fridge, what can I do?
  • 1,602 Answers
Now if the refrigerator is leaking cold air from the freezer, that is normal, there should be a vent, or control handle near or inside the frigerator on the freezer side of the refigerator, you can open or close so you control how cold you want your food to be cold
Posted on Apr 22, 2015
Testimonial: "Thankyou For your answer. There is water that drips from a vent between the freezer box & the fridge. I lifted the cover on my SR 21 NME Samsung inside the freezer & there are two polystyrene trays that are not occluded or gunky for want of a better word. However it looks like a yellow liquid had sat there for a time & it is a chemical smell compared to a food smell. I have no strange smells or stains inside the fridge. However if I persist in leaving it running to use the freezer box which works fine I get a watery looking mould build up inside the fridge box"
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Just opened my fridge freezer and its stopped working. In fact it was warm from the heat created by the light. What could be wronge with it
IF YOUR FRIDGE FREEZER IS OLD SAY BY 10 OR MORE YEARS, IT COULD BE A FREON LEAK, CHECK THE BACK OF YOUR FRIDGE AND SEE IF THERE IS CONDENSATION ON THE COILS, IF THERE IS NOT CONDENSATION THEN YOU COOLING PUMP COULD BE BAD OR FREON LEAK.
Feb 09, 2013 | Refrigerators
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Leak in fridge from between fridge roof and freezer, fridge is still cold as is freezer however will not stop leaking
Hi, The drain hole located in the freezer defrost drain is plugged. Get me your model # and I can assist you further.
THanks
Vic
May 17, 2009 | Refrigerators
Freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
May 10, 2009 | Refrigerators
Bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Leaking inside of fridge
i guess u will benifit from this link
plz rate this post
click here
Sep 02, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer smell
could be that your freezer is leaking gases some leaks are fixable but if its an internal leak you will have to replace the complete appliance
Aug 15, 2007 | Turbo Air TGM22RV
Refrigerators Logo
233 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
