Question about Dayton Heating & Cooling
Dayton over head heater model 3E230 pilot lights and burns good set thermostat its like it kills the whole thing
Pilot lights and burns good set thermostat its like it kills the whole thing have bypassed the thermostat and same thing cant find a wiring diagram the fan will turn on after i hook the thermostat wires together the 2 switches in front of fan test good the ceramic i get continuity across the disk switch has 3 wires i jumped across the 2 bottom and fan comes on instantly i do have 24 volts going to the gas valve
  • 306 Answers
SOURCE: Cozy wall furnace - unattached wire, won't turn on
Sounds like one of your limit switches lost it's wire. Look for a disc like device no more bigger then a 50 piece. You will see two wires going to that and if the wire broke take off the insulation and install new plastic sheath and re-attach. Let me know it that is helpful. ken
Posted on Nov 26, 2008
muttandjeff
  • 359 Answers
SOURCE: Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Posted on Dec 23, 2008
  • 92 Answers
SOURCE: Why does a pilot light go out,but the fan keeps running?
some heaters use a timer to bring fan on as opposed to some which use temp
Posted on Feb 24, 2009
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Heater won't turn off. Wires were troubled
Shut off the gas to the heater. Bad gas valve. Gas should not be leaking from any part of the gas valve.
Posted on Oct 21, 2009
Propane smell with pilot on and burner ring/thermostat off. Pilot off no smell. Pilot light is good, burner ring burns cleanly. Logs correctly placed. No line leaks. Failed shutoff valve how to fix?
This is a major hazard, you need to take pictures of the whole thing and then disassemble the whole thing and use ptfe sealant and reassemble the whole thing. Unless you want to get a sniffer to locate the issue, If could also be the pilot pressure is too high and the pilot is not burning all the gas. You may want to call a pro due to explosion risk.
Jan 10, 2016 | Heating & Cooling
Pilot light on my heater keeps going out an I have a hard time lighting it. It's a Royal Jet serial no. Is 55FG385412 Model FG355 help if u can
Get the pilot light sensor replaced as the burn down with use and if they are just out of spec the sensor cools and shuts off the gas flow for safety
Dec 05, 2015 | Dayton Gas Furnace Heater
Heater will not light when turned on.
depending on your ignition sorce pilot light or glow plug check for cracks or chips. if you have a glow plug do not touch with your hands. oil from hands will cause them to burn out.
Jan 15, 2014 | Dayton (3E461) InfraRed Heater
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
Pilot light
Hi the thermocouple is a long copper wire that goes back to the gas valve from the pilot .
i would clean the flame senser first , then check the pressure switch jump this out , then check the fan control or snap disc jump this out see if it runs if you need A THERMOCOUPLE then honeywell universal will do
Apr 07, 2009 | Dayton (4LX41) Heater
Dayton Furnace - Pilot Light Goes Out but Fan keeps running?
Pilot lighted furnaces have a thermocouple made from disasimilar metals that when heated create electricity to actuate a relay that alows the gas to flow to the furnace.
When the thermocouple gets coated with carbon from the pilot lights constant burning it acts as an insulator and keeps the thermocouple from getting enough heat to generate electricity, a very good safety factor.
What you have to do is locate the thermocouple it should be located over the pilot light, you will see a gray substance around the thermocouple it will be hard like cement, take a knife and scrape away as much of the gray material as possible then sand the themocouple with a medium sandpaper until it shines, use one of you wifes emery boards, this should solve your problem.
Feb 24, 2009 | Dayton (4LX41) Heater
Pilot light goes out when turning on the thermostat
Check your thermocoupling to make sure that it is sensing flame. You can tell if it is good or bad by the white on the tip of the flame sensor. The other problem would be a blocked or closed flue pipe. Make sure that the cap is not smashed down on the pipe on your roof
Feb 13, 2009 | Dayton (3E386) Heater
Cozy natural gas heater Mod # CLV 335A
get someone to check the gas pressure that is poss problem gas company if nat and the lp supplier can do it
Dec 17, 2008 | Cozy Enclosed Front Console Heater 20,000...
Heating & Cooling Logo
116 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
