Question about Wilson Jones Office Equipment & Supplies
How do i open an lv340hs wilson jones laminator after screws are removed?
2 Suggested Answers
  • 3 Answers
SOURCE: Paper Jam in Wilson Jones 1500. Reverse doesn't
You should probably unplug it. Two screws in back and under. Slide front cover back an inch.Disconnect cable and clean unit with vacuum.
You can hand cycle it in both directions to loosen up the blades.
Posted on Apr 18, 2011
My 17 year old Wilson Jones 1153 Model shredder can't be left plugged in-It drains the electrical circuits and turns our heater off. Other than that,it works great.Is this worth repairing-Suggestions?
Just take it apart and unplug the switch that is keeping it on. take pictures when you pull apart the cases. sometimes some of the screws are under labels. Should be no more than five screws. Paper has an oily presence and causes these type of failures.
Apr 18, 2017 | Wilson Jones Office Equipment & Supplies
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
User Guide for the machine
i need clubpenguin unused membership
May 01, 2013 | Wilson Jones CB256 Comb Binding Machine
How do open and close Wilson Jones 365-49 Large Handing Post Binder
Open the binder flat, press the top right stick thing (sorry, don't know a better word for it), and press it to your right. Lift the metal (right side) up and out. To put back in, just place in the papers, and then take the right metal strip of three prongs, and snap it back into place. Hope this makes sense.
Apr 05, 2012 | Wilson Jones 365-49 Large Hanging Post...
Shredder is Wilson Jones 130 auto. I believe staff shredded to many sheets at one time. No no lights no power forwards or backwards. Is there a reset or fuse, can't find one
Oddly, my Wilson Jones 130 auto just did exactly the same thing. I'm the only one that uses it (that I know of) and one day it worked, the next it didn't. There is no paper stuck in it. There are no power lights, nothing works. Does anyone know the location of a reset button or something?
Jun 21, 2011 | Office Equipment & Supplies
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
Paper Jam in Wilson Jones 1500. Reverse doesn't clear it. Is the plastic cover where the paper is fed removable?
Aug 12, 2009 | Office Equipment & Supplies
HOW TO GET A 3700B TRIMMER APART
Before you start anything go to Makitatools.com and type in your model number on the upper right hand side of the site, go to the area below pic of your trimmer and download a schematic for this. Its not really that hard to get it apart.
Apr 01, 2009 | Makita 3700B - Laminate Trimmer Tools
Hi, Our Ibico IL19VT Laminator (A2) has paper jammed inside of it. There are no reverse mechanisms on the laminator. The only feasible method is to open the laminator up at this point, whether or not...
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Aug 21, 2008 | Office Equipment & Supplies
85 people viewed this question
Top Wilson Jones Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Wilson Jones Office Equipment and Supply Expert? Answer questions, earn points and help others
