Loud ticking noise coming from what sounds like motor which slows down nearly to stop then speeds up. Now stopped mid-cycle. Is it the motor?
    Master:
  • 456 Answers
It sounds like the brushes are on there way out in the motor, check numbers from the motor and you can buy them on line ..hope this helps
Posted on Apr 22, 2015
How do i repair a lg washer that makes a grinding noise when slowing down from spin cycle
It sounds as if the tub bearing on your machine is faulty. To replace this bearing one needs to basically strip down the entire machine.
Not a job for a novice.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
I have a 1997 wrangler sport, It is a summer toy basically so we mostly drive it when the weather is nice. However yesterday it started to rain and I had to turn the wipers on and I noticed they gradually...
Surely sounds like the wiper motor is burned out. You might be able to get the wipers back to the park position if you assist them through the full cycle they normally travel. In other words, if they were just going up, you have to let them travel all the way to the left side and them they might be able to come back all the way down.
Sep 22, 2010 | 1995 Jeep Wrangler
Clicking sound on Washer Spin Cycle
You are quite correct in thinking that it is the motor brushes that are worn.
You need to remove the motor and replace the brushes.
This will solve your problem.
Good luck.
Nov 28, 2009 | Bosch Axxis WFL 2060 Front Load Washer
1990 Dolphin Motorhome Dometic AC problem
If your fan motor is slowing or stopping mid cycle it will cause the compressor to over pressurize. Many compressors have aan internal mechanism that will kick in with a loud whooshing noise, then the Thermal protector shuts the compressor off, cools then restarts. If this sounds familiar, you will need to replace your fan motor before you burn up your compressor...which to be honest may already be irreparbly damaged(sorry). Hoping 4 the best.
Jul 11, 2009 | GE Quiet-Aire Ductless Split System Air...
Tick In motor every few seconds after intake gasket changed
Sounds like when they did the intake,They drained the fluids but forgot to fill them back up and since the oil was near empty,I would say it's a lifter.But they can be reprimed or replaced a whole lot easier than some other possible causes.
May 14, 2009 | 1998 Ford F150 Regular Cab
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Loud Ticking/knocking Noise From motor; What is it?????
could be yur water pump going do you leak anti freeze or oil? also if a older model could be ot of timeing check your distributor cap and see if its loose
good luck
Jan 21, 2009 | 1996 GMC Jimmy
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
