Question about Garden
Idler pulley started contacting the front blade pulley
The idler pulley is hitting the front blade pulley.the idler pulley has the torsion spring.
  • 1,548 Answers
Check for worn bearings on the idler and front blade pulleys. Also, verify that idler pulley spring has adequate tension.
Posted on Apr 22, 2015
Testimonial: "paul,i sure appreciate your help on the idler pulley.thanks,kenny"
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
I have a zero turn radius mower it runs blades spin machine will not move. Is there a pulley tensioner to adjust?
There is a spring loaded idler pulley that keeps the drive belt tight. The spring selfs adjust it. But make sure your bypass valves are not release to roll it around. If the belt wears to thin it will hit the bottom of the pulley and will slip . I doubt both drive units went bad at the same time.
Aug 23, 2016 | Garden
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
LT1000 917`274352 craftsman blades turn when starting mower
Sounds like the idler isn't releasing for some reason. Check that idler spring is in place and check that clutch cable as they tend to bind up as they get well used. Also the idler arm itself for binding.
Jan 17, 2015 | Craftsman Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Need to know routing of mower deck belt
Generically speaking for most decks, stand at the back of the deck with it removed from the tractor. Take a marker if needed and draw arrows on the deck to show which way the blades should be turning. Typically the leading edge (front of the deck) of the blades spins toward the side discharge. Belts are almost ALWAYS routed to provide as close to 180 degrees of wrap around the pulleys as possible, never less than 120 degrees as that would cause too much slippage. Wrap the belt around the blade pulleys and you will have quite a bit of belt left over. That gets used to wrap around the spring mounted idler Look at the spring mounted idler. You want the belt to go around the idler in such a way that it will pull against the spring, not push against the spring. A little patience and a little logic, and you can figure out just about any deck belt routing with no drawing.
May 02, 2011 | Garden
Problem Engaging / Disengaging the Blades
Two separate issues:
For free wheeling blades, it is time to replace the following items:
Brake Arm Pad Assembly # 131845X900 (Item 53 in picture)
and depending on condition:
Torsion Brake Spring(s) # 140086 (#58 in picture)
Take a look at Idler Pulley # 131494 (#36 in pictur, checking for wear. Sand and other abrasives will eventually wear the pulley down.
For engagement of handle: Lubricate all moving parts associated with the handle. Use only a dry film moly lubricant. Do NOT use WD40 as it is a penetrating oil and offers very little lubricating properties. Do not use oil as it will only attract dirt and eventually clog everything up.
The idler pulley previously described is on an articulating arm that must move freely, otherwise it will be (1) hard to engage and (2) cause slack when disengaged. In addition, this will result in premature belt failure.
FYI, although a Craftsman badge, this is an AYP (American Yard Product) tractor with a Murray Deck. Keep this in mind when ordering parts so you don't pay for "name branding".
Please let me know if I may assist further.
Best regards.
May 06, 2010 | Garden
WHEN I HIT START BUTTON, IT JUST HUMS, DOESN'T START DRUM
Suspect a broken drive belt. Open the top to check. On some models, you need to push two spring clips inward--one on each front corner with a thin putty knife. On others, remove several screws from the back edge and slide the top back. To install a new belt, the front panel must come away from the cabinet to pass the belt over the drum. Remove a lower back panel to place the belt over the motor pulley and spring loaded idler pulley.
Feb 02, 2010 | Dryers
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
To adjust the drive belt:
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
Apr 12, 2009 | Garden
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
