Question about 1988 to 1989 Chevy 2500 Pickup Truck 100% ALL CHROME Grille Grill
My 1989 chevy truck suddenly started squealing loudly when I push in the clutch to change gears. Do you think it is the flywheel or throw out bearing?
    Sergeant:
  • AM Auto Parts Expert
  • 304 Answers
I agree its gonna be a bad throw out bearing. If your gonna do all that work just buy the complete clutch kit and do it once.
Posted on May 17, 2015
  • AM Auto Parts Master
  • 991 Answers
It will be the throw out bearing.
Posted on Apr 22, 2015
Cluth is making a loud screeching noise when changing gear and when starting the car up.
Is it squeeling or a sound like metal to metal as if it squeels, then perhaps your alternator is getting bad or your serp belt, if its the other than perhaps your clutch maybe going start with the clutch flywheel hope that helps
Apr 27, 2016 | Cars & Trucks
Clutch started squealing on my f350 then hard to engage in gear
The transmission will need to be removed. Probably will need a new clutch disc, pressure plate, release bearing and pilot bearing. The flywheel should be removed and taking to a machine shop to have them resurface it.
Sep 08, 2014 | Ford F-350 Cars & Trucks
The clutch was having a hard time going into gear.All of a sudden there was a high pitched squeal/scream coming from the transmission area.
that sounds like a throw out bearing failure-is there any adjustment at the slave cylinder-it may be holding the bearing against the clutch and causing the noise-this thread may help-http://www.jeepforum.com/forum/f9/how-change-bleed-clutch-slave-cylinder-511531/- cheers Denny
Dec 22, 2013 | 2000 Jeep Wrangler
Squealing when shifting into gear
You have a failed clutch throw out bearing
Mar 01, 2013 | Chevrolet Blazer Cars & Trucks
99 f550 cluch will not disengage. It sounded like a bearing was squealing when I would push in the cluch. Do you know if this has a hydraulic slave cylinder that may not be disengaging? Is there a throw...
You should be able to remove a cover or inspection plate at the bottom of the ****** bell housing to inspect and visually see the throw out bearing. It sound like it (the throw out bearing) completely went out or damaged the fingers it rests on to disengage the pressure plate. All clutches are pretty much the same. Flywheel bolts to the rear of the crankshaft with a pilot bearing in the center for the input shaft. The clutch disk is sandwiched between the flywheel and retained in place by the pressure plate. Followed by the throw out bearing which is operated by the release fork. You could have a bad slave cylinder, but that would not be the source for the squealing you hear. Sounds like it's time to replace the clutch assembly.
Aug 27, 2011 | 1999 Ford Super Duty F 550
Squealing noise stops when i push in clutch pedal we were on the interstate and suddenly i had no clutch pedal we got off the street it was hard to get it out of gear i checked the fluid it was fine...
Sounds like a bad Throw Out Bearing.. Needless to say.. it has to be repaired.
Depending on mileage.. may as well replace the clutch/pressure plate.. and have he flywheel looked at.. change the tranny oil.. check the u joints.. rear end etc..
Best of luck!
Apr 09, 2011 | 1997 Chevrolet Camaro
My 1994 mazda protege xl won't change into 2-5 gears. i have no neutral and it's stuck in 1st gear. is my transmission gone ! or my clutch !
sound's like the throw out bearing wen't this it what move's the clutch away from the flywheel when u push in the clutch peday if this fai's the tranny could be fine but u will have to remove the tanny to replace the throw out bearing and clutch asembaly
Jun 04, 2010 | 1994 Mazda Protege
Craftsman Tiller makes loud, shrill, squealing noise when tilling
Noise comes and goes sound like metal on metal not a belt squealing
Apr 03, 2009 | Craftsman Garden
Clutch makes a squealing noise
Hello;
The throw out bearing is going oout. The reason you hear the squeal when you push in the clutch is that is when the throw out bearing spins up. Rest of the time it does not spin.It is irratating, You should replace the entire clutch assembly when you replace the throw out bearing. Hope this helps, rate me high.
Thanks;
Rich
RPM Northwest
Feb 02, 2009 | 1998 Dodge Dakota
1988 to 1989 Chevy 2500 Pickup Truck 100% ALL CHROME Grille Grill Logo
73 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
noagge
terry stevens
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
