Question about Samsung Washing Machines
My Samsung top loader does not drain water - Samsung Washing Machines
  • 3 Answers
Your pump is blocked by something... I had this happen with my asko washer and I had to undo the pump and dig around till I got something...I found some loose change and paper clips covered in gross washing machine stuff i don't know what but it was gross!
Posted on Apr 27, 2015
    Genius:
  • Samsung Master
  • 1,585 Answers
Pump probly blocked
Posted on Apr 26, 2015
IFIXALL
  • 868 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
  • 66 Answers
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Posted on Nov 27, 2008
futureloginn
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 713 Answers
SOURCE: Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Posted on Apr 10, 2010
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung top loader 5e error
5E= WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Nov 07, 2012 | Washing Machines
WASHING MACHINE NOT RETAINING WATER
Make sure that
A. the drain hose is above the hight of the water level.
B. there is an "air gap" between the drain hose and the stand pipe as the water can "syphon"out.
May 04, 2012 | Samsung Washing Machines
De error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 28, 2010 | Samsung SW62ASP Top Load Washer
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
56 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
