Question about Ovens
Need same size replacement W x H
Unit is built into the wall and we want to use the same footprint if possible.
  • 932 Answers
Rick,
Getting an exact match might be hard. I would suggest starting with the same brand you have and go to their website and look at the specs page and that will show you what you would need to be looking for. The other option that I can think of is contacting a local appliance store in your area and give them the dimensions of what you are looking for and let them do the leg work and see what they can come up with for you.
Posted on Apr 22, 2015
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Sep 27, 2014 | Frigidaire 24" Single Gas Wall Oven with...
I HAVE A AMANA SINGLE WALL OVEN THE ELEMENT SPARKED AT THE BACK OF THE WALL. I PURCHASED A NEWW ELEMENT AND WHENITOOK THE OLD ONE OUT THERE WAS NO WIRE TERMINALS AT THE ENDS OF THE PLUG IN END OF THE...
when it burnt off it fell somewhere between the oven chamber and the back panel.once finding it,its just a matter of splicing a new wire terminal end and attaching it to the element. The problem lies in thats its a built in wall oven and may be needed to be removed from the cabinet to find and repair this wire. Depending how tight it fits into the cabinet it may not come out easily and even break the wood around the cabinet. which of course you could face in pulling it out to replace it with a new oven. ONe thing to keep in mind is that all wall ovens are slightly different in size and the replacement oven needs to be pretty close to the size of existing one or the cabinet will need to cut or filled in so their wont be a gap left when new one is smaller leaving a gap in cabinet up to 2 inches on either top or side walls
Aug 13, 2011 | Amana Ovens
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
Gas connection on bottom of oven does not accept std 1/2'' flex hose?
all gas connections are flair fittings if the 1/2 inch is to large a 3/8 inch is the mext size down. if the 1/2 is too small the next size up is 5/8
Sep 03, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
Sep 01, 2009 | Frigidaire 24" Single Gas Wall Oven with...
We had a power outage and the oven will not work, after shutting off the power the panel lit up with all 8888s and will not work
Forgive me for saying this, turn the unit off wait 30seconds, then turn on again (this sometimes works)
There is a very good possibility you have suffered a power surge which has damaged your electronics unit. Please check your manual to see if there is a reset button on the display (this sometimes reolves it).
If there is no way to reset, then you will need to replace the displat/circuit board, this is quite fiddly and i would recommend you call in an appliance expert.
I hope this helps.
Jul 08, 2009 | GE PT956CMCC Profile 30" Built-In Double...
After doing a self clean, the panel now flashes locked
thermal protector has caused lockout. happens w/ self clean a lot. it's a small thermostat device most likely on the rear of the oven. oven need to be pulled from wall to check/replace. you may have to open door w/a coat hanger if it's locked to get the door open to allow access to screws to allow removal of oven from wall if it's a built in. unplug it before doing anything. fuse is under back cover size of a bottle cap, 2 wires, should be "closed" normally. replace or spray w/freon to "reset" it.
May 25, 2009 | GE Profile 30" Built-In Single Electric...
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
How to install built in oven
when they say 24'' or 27'' wall oven are they saying rough wall opening size or the front is 24'' 27'' across the front
Sep 08, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
