Question about Epson Stylus Pro 9880 44" Printer Colorburst Edition
Has anyone recommend me the link free download WASTE INK COUNTER resetter
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
SOURCE: epson pm210 printer waste ink pad resetter
we want service requaired for pm210 printer
Posted on Sep 01, 2009
pineworks
  • 4041 Answers
SOURCE: How do I reset waste ink counter?
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Mar 17, 2010
pineworks
  • 4041 Answers
SOURCE: Is there any way of clearing the waste ink
Main features.
Download Free
Posted on Apr 25, 2010
Epson 1390 service is required.
download free software resetter epson stylus photo 1390
Jan 10, 2011 | Office Equipment & Supplies
Cannon Pixma IP1600 is full and will not print, how do I fix it
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 26, 2010 | Canon PIXMA iP1600 Printer
Printer says inkjet not installed properly but it is and both are full.
Hi there
4.Close The Cover
Feb 23, 2010 | Canon PIXMA iP1600 Printer
I have a Cannon iP1600 printer and when i want it to print, it tells me that the waste ink absorber is full. How can I fix it?
Hi there
4.Close The Cover
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Every i try to print i get an error message 53 stating the ink cartridge is not installed properly or not compatible with the printer
Hi there
4.Close The Cover
Nov 30, 2009 | Canon PIXMA iP1600 Printer
Computer wont reconize ink cartidge
Hi there
4.Close The Cover
Nov 02, 2009 | Canon PIXMA iP1600 Printer
Help!Have Canon printer.Changed cartridge, but can't print!
Hi there
4.Close The Cover
Oct 16, 2009 | Canon PIXMA iP1600 Printer
Canon Pixma ip1700 how to clean a full ink observer?
Hi there
4.Close The Cover
Jul 08, 2009 | Canon PIXMA iP1600 Printer
Ip1200 takes in paper on right only- tells me paper is out
Hi there
4.Close The Cover
Oct 18, 2008 | Canon PIXMA iP1600 Printer
Error message
Hi there
4.Close The Cover
Jun 30, 2008 | Canon PIXMA iP1600 Printer
Epson Stylus Pro 9880 44" Printer Colorburst Edition Logo
267 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
