Question about LG Televison & Video
Hi I have A LG 60pv450 And it won't come on - LG Televison & Video
LG plasma 60pv450 has stopped working. It turns on and after a few seconds it shuts off. I can't get it to turn back on. There is a standby light on.
The set is going into safety mode. This could be one of many problems and we would need to inspect the set.
Jan 05, 2017 | LG 60 60PV450 Plasma TV
My lg 60pv450 plasma picture is kind of redish and not so bright and clear any idea what board needs replace cannot afford a new one
The TCON board or the LCD panel is faulty can confirm by replacing the TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 04, 2017 | LG Televison & Video
Lg 60pv450 tv
Lg 60pv450 suddenly went black. Red standby light is on. When I select "input" or try to change the channel, tv turns off.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here....
Dec 25, 2016 | LG 60 60PV450 Plasma TV
Plasma tv has no picture
Does it have sound? Need as much info as you can provide to assist in determining just what may be the issue.
Mar 25, 2016 | LG 60PV450 60-Inch 1080p Plasma HDTV
Which board is probably faulty? LG 60 60PV450 Plasma TV
Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 18, 2016 | LG Televison & Video
I have an LG 60 inch plasma model 60PV450 that has no picture but does have sound
It is probably the backlight inverter board. These are common problems on all LCD and Plasma units that use fluorescent backlighting.
Jan 20, 2015 | LG 60 60PV450 Plasma TV
My plasma tv just started having water colors flashing on top and bottom?
Contact the authorized service centre for LG. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 04, 2015 | LG 60PV450 60-Inch 1080p Plasma HDTV
Fickering green red colors
Sounds like panel fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD are given. You can see and compare to that ot your TVs', and can make sure about the fault to an extent.
Apr 24, 2014 | LG 60 60PV450 Plasma TV
Lg 60 replacement screen
there is a bar code label on the inside on the panel--be careful as we have to photo that and have LG id the part and the display panel has to be the exact one---cost of a new one more than a new set.....
Oct 17, 2012 | LG 60 60PV450 Plasma TV
Televison & Video Logo
44 people viewed this question
Computer Repairing
Computer Repairing
