Question about Ricoh Aficiompc2550spf Color Digital Copy Print Scan Fax mpc2550spf
It keep saying to use the following functions set key counter
3 Suggested Answers
  • 24 Answers
SOURCE: our printer keeps saying set counter?
can you provide more info?
Posted on Oct 05, 2008
  • 15 Answers
SOURCE: Set Key Counter error
press the user tools button, press the copier button on the screen then go into the administrator tools button in there you should see some option for turning the key counter off.
Posted on Mar 01, 2009
My brother printer is saying it can't clean. It normally does this when I turn it on.
Here are several pages which tackle this problem. Some include pictures as well as explanation.
How do clear the message Unable to or Unable Brother
Determine the error code by the following. unplug the unit, hold down the Menu/Set key, re-insert the power plug while holding down the Menu/Set key. The internal Machine Error Code will be displayed. Unplug and re-plug the unit again. You should get error code 46. If so:
Dismantle the printer, replace the ink absorber box (or possibly break it open and clean its sponges under a tap). Re-assemble the printer and reset the purge counter to zero. The counter is reset as follows according to Ronald Massey:
  1. Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
  2. FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
  3. Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the up arrow key four times to enter the maintenance mode).
    1. Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
    2. Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
    3. Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
  4. Press the Stop/Exit key to return to the initial stage of the maintenance mode.
  5. Press the 9 key twice to return to the standby state
And here is a link to unclog printer nozzles:
Error
Nov 26, 2017 | Brother Office Equipment & Supplies
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
Ricoh mp 5000 it's in indicating to use the following function, set key counter how do I resert it please help?
Go into "User tools"
Select "System Settings"
Select "Administrator Settings"
Look for "External charge unit" or "Key counter management" and turn it off.
Exit the "User tools" and you should be done.
May 13, 2016 | Ricoh Aficio MP5000
It says "unable to clean"
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Dec 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
Hello there i have a lanier color copier everthing work and functional fine acceipt when i want making color copy, i press full color button the display panel show TO USE THE FOLLOWING FUNCTION [ S ] SET...
Hi, whoever administrates that copier has set it up for key counter management, which means that unless you supply the correct key (which is typically a card that you swipe or a code you enter) you can't make color copies. If this is your copier, you can disable key counter management:
- Press the User Tools/Counter button. - Go to System Settings. - Go to Admin Tools. - Find the option for Key Counter Management and turn it off. - Exit out of User Tools.
Now you should be able to make copies normally.
Dec 02, 2010 | Lanier UNKNOWN
Hello there i have a lanier copier model ld 160c color copier everthing work fine and functional acceipt i can not make full color copy, when i press the full color button then the display panel show up TO...
Hi, somehow the external key counter option for your copier got turned on. This option is typically used for coin-operated copiers such as those found in libraries. You can turn this option off by doing the following:
- Press the User Tools button - Select System Settings - Select Admin Tools - Select Key Counter Management - Choose Off, or de-select the full-color option if it is selected. - Exit out of User Tools
Now you should be able to copy normally!
So reset PM counter on tne pf-7718 panasonic?
hold together the following keys
Function, User reset, 3
display should appear F1
Press 7 and press Start key
go to maintenance counter and reset it
Apr 09, 2010 | Panasonic FP-7735 Black and White Copier
Reset the drum counter
There, there is counter, which it is necessary to throw each 12 thous.. (making at preventive maintenance of the printer). For installation new cartridge it is necessary simultaneously to press shift Ctrl F1.
In connection with extension market copiers Panasonic and with all becoming more frequent questions in Conferences has solved be divided accumulated by information.
The Whole hereinafter presented information pertains to device of the serieses DP
Now about that, what fall into service mode; for entering we press consecutively: key "FUNCTION", key "ORIGINAL SIZE", key "3".
For emergency input in switched off condition hold the keys "FUNCTION" and "STOP" for DP-1515, for the other device - a keys "FUNCTION and "CLEAR", and snap the tumbler of the feeding.
Now we in service mode, possible installthe developer; for what we call at in mode F8-09 and wait the completions of the process for 3 minutes. If this first start or was changed the drum, that executes the procedure F8-14. For leaving from service mode жмем on keys "FUNCTION" simultaneously and "Clear".
Most often used functions of the service mode:
F7 02 General counters mines
F7 03 Counters mines before following preventive maintenance Unset "wrench" is produced by record in cell F7-03 importances 0
F7 06 Counters mines on installed drum
F7 10 Counters mines on the same developer
Oct 12, 2009 | Panasonic DP-C264 Copier
Brother MFC-210C keeps displaying unable to clean messasge
Hi I found this on your website for this problem, from Poster "Trickydicky": Rank: Apprentice
Rating: 96%, 81 votes
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C): I havent tried it yet but there were many recommendations from users who did and they recommend this solution- Good Luck the service centers said it would be $70.00 just to check it before any work is done. But if it's just a matter of pressing series of buttons to reset the cleaning counter, it's worth trying. REE
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Carry on printing !!
Was this solution helpful? Show your Appreciation by rating it:
Dec 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
Hi, I have a Brother MFC-210C that keeps telling me its unable to clean, I followed the user manual but it keeps displying the same message, what do I do now? please help
For Brother MFC210C Printer Fax Copy Scan
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode).( "The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Ricoh Aficiompc2550spf Color Digital Copy Print Scan Fax mpc2550spf Logo
182 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
