Water won't come in. what is wrong? - Washing Machines
  • 3,961 Answers
A common cause is failure of the inlet valve, which is normally held open by an electrically operated solenoid.
Posted on Apr 22, 2015
Hi there I've got a 05 polaris predator 500 Tory
hi try cleaning the carb or check your air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. Best of luck!
Aug 28, 2013 | Garden
Won,t pump water
have you tried sending it to a shop to see what's wrong. it might just be the motor has burned out.
May 15, 2013 | Pool & Spa
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
Water won't drain.how do I know if drain hoses are
The problem is more likely a clogged pump or maybe a clogged drain line. If the machine worked at all, that would eliminate wrong connection of the drain line as a cause
Mar 25, 2013 | Washing Machines
2004 Vitoria 111cdi. Just started to not unlock, only when feels like it and when put key remote in ingnition won't even recognise and won't turn so can't start. Sometimes fine but other times...
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Sep 24, 2012 | Cars & Trucks
Washer will not rinse on any cycle
Well if it won't rinse it won't pump out wither right? The pump is mounted on the motor. The motor won't pump or spin if the lid is open. I would check the lid switch
When this pump is going counterclockwise the water stays put. The machine agitates.
When time for rinse the motor goes opposite direction. If the lid is open the washer will not spin or pump out. I suspect you must have a lidswitch issue. Here is a video which shows how to check it without guessingthemobilian_3073.jpg
Oct 26, 2011 | Kenmore 23822 Top Load Washer
It does run yet won"t heat up!!
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 08, 2011 | Crosley DCW25-1 Dehumidifier
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Washing Machines Logo
Top Washing Machines Experts
