Hope these instructons might help you
http://service.us.panasonic.com/OPERMANPDF/SAAK340.PDF
SOURCE: factory radio recieves am stations only no fm stereo
get a new one as they are cheap these days!
& not worth the labour costs to try & fix them anymore!
Cheers Rob
SOURCE: CAR STEREO HAS POWER BUT WILL NOT OPPERRATE
There isn't a way to repair this in your car, it is an expensive dealer repair. I recommend that you obtain a good after market replacement. You will then have a new radio with a warrenty and it will cost you MUCH less.
SOURCE: radio stations
There is a radio option to recalibrate your touch screen. Please press the following three hard keys simultaneously RADIO/MEDIA, SEEK UP, NAV (AUDIO on REN). Once you begin to recalibrate the touch screen you must finish. Audio confirmation prompts are provided for each of the three points of calibration, one beep for the first, two for the second and three for the third. The calibration needs to be precise as possible and a PDA stylus would be recommended. The MyGIG radio requires the user to repress each calibration point to confirm the calibration process. A green crosshair indicates proper calibration.You must not start with the "+" but with the "+1", then goto "+2" and last to "+". Repeat this until all crosses are green and exit with pushing the menue or any other key. Done
