Question about Plantronics Voyager Legend Bluetooth Headset - 87300-01
Why doesnt my headset work when i dial a number from my phone
Can hear but other party cannot hear me
There are a couple of things you need to check. First, make sure it's connected correctly to the phone. This guide should help you with that:
Plantronics CS70N User's Guide
Secondly, the compatibility dial on the left side of the base has numbers 1-4. The indicator to the right of the dial needs to point to one of the numbers, never between numbers. Most phones operate using #1 for compatibility but you can dial in the others if you're still having issues. That should get you up and running.
Good luck from Headsets Direct!
Jan 24, 2012 | Plantronics CS70 Wireless Headset
The headset picks up but it doesnt answer the phone. CS70 NC headset.
If it's not answering the phone, your phone may need to be programmed for auto-pick up so that it automatically opens the telephone line when you turn on your headset. Also, make sure the round compatibility dial (located to the left of the base) is set right (not between numbers and most phones work on setting #1).
Good luck from Headsets Direct - 800-914-7996.
Aug 09, 2011 | Plantronics CS70 Wireless Headset
Issue using software to dial out
Press the Headset button that is right below the speaker button. Make sure that stays lit all the time.
Feb 18, 2010 | Avaya 5400 Series 5410 Phone
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
I have two Bluetooth-enabled devices from Motorola: (1) DECT cordless phone (B802) and (2) headset (H790). They are paired. I can use the headset to answer calls, however, I can't make headset to work when...
If this is happening while the headset is connected either the Motorola or DECT, then there's a problem with the small circuit board or the program of the headset. Small electronic devices have their program called the firmware.
BUT first, try using another Bluetooth headset and connect it to both phones (one at a time) and then test it with outgoing call. If it does work, then the problem is isolated with your problem headset.
For this kind of problem, you need to contact the manufacturer of your headset for repair.
Good luck and have a great day!
Jan 13, 2010 | Cell Phones
My samsung trance phone was connected to hands free head-set, but now that I have unplugged the headset, I cannot hear sound through the phone itself when making calls, it only works with the headset. what...
I just figured this out. When you unplug the headset it will open up the voice activated dialing. Instead of cancelling out of it (like i did a bunch of times...) use your voice to dial someone (anyone's) number. It should dial and the phone should work normally after that.. weird but it worked for me.
Nov 29, 2009 | Samsung Trance SCH-u490 Cell Phone
H700 now only dials last number called
On mine, if I wait for it to be fully connected with the phone, then press the button one time, the blackberry ask for the correct voice command. However, if I press the button twice, it will dial the last number called.
Aug 02, 2009 | Motorola Mobility H700 Wireless Headset
Voice dialing
Shelly, I use a nokia N90 and you are right that one can not call by voice dialing. What I did was put the phone numbers that I frequently call in speed dial. Whe I want to call somebody I just press the speed dial number.
Oct 05, 2007 | Motorola Mobility H350 Wireless Headset
Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
Jun 21, 2007 | Motorola Mobility H700 Wireless Headset
Plantronics Voyager Legend Bluetooth Headset - 87300-01 Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
