Question about LG 37LC2RR 37 in. LCD TV
The time-delay do not work.Cannot format the HD.
46 inch samsung delay in turning on
Delay in turning on is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Dec 29, 2013 | LG RU-42PX10 42 in. HD-Ready Plasma...
Tip
Mac HD Converter ? The prefect HD video converter to convert HD video on Mac OS
Doremisoft HD Video Converter for Mac is the perfect Mac HD converter to convert HD video and convert video to HD on Mac OS. It can convert HD videos such as MTS, M2TS, TS, MKV, TP, TRP, M5S, MOD, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD etc. and regular videos such as AVI, ASF, MPEG1, MPEG2, MPEG4, MOV, FLV, 3GP, 3G2, DIVX, M4V etc. to various video formats and almost all players.
Doremisoft HD Video Converter is for Mac also an excellent Mac audio converter, it can convert all sorts of popular audio formats such as MP3, WAV, AAC, AC3, AMR, MP2, FLAC, OGG and AIFF to all popular audio formats so you can play your music on different players. With Doremisoft HD Converter for Mac, you can also convert video to audio and extract audio tracks from your favorite video files.
Doremisoft HD Video Converter for Mac is also an easy HD video editor to edit HD video on Mac by cropping HD video to remove unwanted sides or area, trimming HD video length to capture clips from your HD video files, editing video effects such as brightness and contrast, applying special effects etc.
Key Features of Doremisoft HD Converter for Mac
Convert HD video to different formats and players on Mac
Work as an excellent MKV converter/MOD converter/MTS converter/TOD converter. Convert various HD video formats including MTS, M2TS, TS, MKV, TP, TRP, M5S, MOD, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD, Flip MP4 HD to various formats such as MKV, 3GP, 3G2, MPEG1, MPEG2, MPEG4, FLV, SWF, DV, M4V and MOV and so on, and to all sorts of players including iPod, iPhone, Apple TV, PSP, Creative Zen, cell phones, Zune, BlackBerry, Gphone, iRiver, Palm, Walkman, Gphone etc.
Convert regular video to different formats and players on Mac
Convert regular video formats including AVI, ASF, MPEG1, MPEG2, MPEG4, MOV, FLV, 3GP, 3G2, DIVX, M4V etc. to various formats such as MKV, 3GP, 3G2, MPEG1, MPEG2, MPEG4, FLV, SWF, DV, M4V and MOV and so on, and to all sorts of players including iPod, iPhone, Apple TV, PSP, Creative Zen, cell phones, Zune, BlackBerry, Gphone, iRiver, Palm, Walkman, Gphone etc.
Convert video to HD format on Mac
Convert HD video to other HD video formats and convert regular video files to HD compatible formats.
Convert audio to audio and video to audio on Mac
Convert all sorts of popular audio formats to one another for playback on all major players, and extract audio from HD video and regular videos to output in popular audio formats.
Merge multiple videos
Join and convert multiple separated HD videos and regular videos to one single file.
Trim HD video length
Capture video clips from HD video and regular video to only convert your favorite parts.
Crop video
Crop to get rid of redundant parts such as the black sides around your video and any part you want to remove.
Edit video effect
Edit video brightness, contrast and saturation, and set special video effects such as embossment, old film, gray etc.
Instant preview
Come with two preview windows to let you preview the editing results real time.
Capture video snapshots
Take snapshots off videos and save the snapshots as JPG, PNG or BMP.
on Jun 21, 2010 | Computers & Internet
Sound delay when using a hdmi cable
It is normal and real stupid---either ignore it (I won't) or go component as in a blind test done at our shop people could not tell on identical sets on HD program which was HDMI and which was Component---most of the time they thought the component was the HDMI picture
Apr 02, 2012 | Westinghouse 26" LCD Flat-Panel HDTV
Cannot convert video files with mtv converter, using windows vista
use another video converter, I'd recommend asoftech video converter as it helped me many time
http://www.asoftech.com/video-converter/
Feb 20, 2011 | Transcend T.sonic 850 Digital Media Player
Mac 10.4.11 Acom data hd/ the hard drive does not show on desktop or file menu. does show in the disk utility.
Is this working before with this Mac Tiger? Or is this the first time you're connecting this HD to your computer?
If first time, there's a possibility that the HD has different file format. It should be formatted as Mac OSX (Journaled) in order for the Mac to recognize it.
If this is working before with this computer, check the status of the HD. Most HDs that could only be detected under the Disk Utility needs a reformat.
IMPORTANT: Formatting the HD would erase all the files inside of it. You may need to bring your HD to the nearest Data Recovery Center to retrieve the files inside and then you may now reformat the HD.
Have a great day!
Jun 30, 2009 | Acom (HD120FE) Hard Drive
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Bip
use a program called Recova to try and get all possible data off the disc, or try a back up program. then using the formatting program off you buffalo disc do a physical format of the disc (it takes a long time). format your disk. (again it takes a long time) If you want to change from fat32 to nfts right click the disk icon ,select properties,format, chose to format in nfts, select quick format. if all ok re-enter your data. it worked for me.
Dec 01, 2008 | Buffalo Technology DriveStation HD-HC500U2...
Sound issue on LG 42LG50
make sure the dish network menu settings in setup under audio are on high. Some tv's require it to be off. Try both and see what works. Also the delay is caused by digital conversion. new stereos have settings for this delay and they have delay boxes for sale online. You could try to change your delay settings on your stereo surround to help. I had to do this.
Nov 29, 2008 | LG 42LG50 42 in. LCD HDTV
LG 37LC2RR 37 in. LCD TV Logo
37 people viewed this question
Computer Repairing
Computer Repairing
