Question about Canon Service Manual For Ir 400
Hallow sir,i have canon-ir-400 xerox machine,develop is 24-24-128 and density is 5 but copy is very light.please solve this problem
When i done develop 16-16-116 and density 9 copy become dark.and when i done develop 24-24-128 and density 5 copy become very light,my picture quality is very poor what can i do
    Welcome Back:
    Visited the website for 2 consecutive days.
Go sevice mode copier audgust HV PRI keep 37
Posted on Apr 26, 2015
Xerox workcenter 7345 erore code 009-383 ?
Your is an "ATC error" indicating that the density test has failed for Black. There are many possibilities, but here are the top 5:
1) Dirty or defective ATC sensor (130K63000) (difficult to reach..recommended to be done by technician)
2) Defective Developer (802k60194) (also difficult) You also need Developer Charge Powder (604K22550)
3) Defective ATC Clutch (121K23270) (also difficult to reach)
4) Drum (013R00624) not turning, or bad drum
5) Drum motor (007K88604) not turning
xerox and tektronix dell canon konica minolta qms samsung lexmark okidata...
Feb 07, 2016 | Xerox Office Equipment & Supplies
Sir i hav a doubt in canon ir 3300.
Hi. have you tried to adjust density in the user mode?
May 01, 2017 | Canon Ir 3300 B/w Copier image Runner...
Machine canon ir 400s error E051
hi sir my xerox machine IR 400 the error code e220
May 12, 2012 | Canon imageRUNNER 400S Copier
SIR,i AM RUNNING IR 400 FOR 2 YEARS THIS TIME ONLY wHEN I CHANGE A DRUM THE PRINT WILL BE GOOD WHEN 200 COPIES CONTINUOUSLY TAKING THE DRUM DAMAGED IT MEANS SMALL CRACK ON THE DRUM AT THE FRONT DOOR SIDE...
first, did you install complete Canon original drum unit or just replaced with not genuine low quality drum?
Maybe the problem is in bad quality of drum.
In original drum unit you get whole unit with new drum, blade and charge roller.
Second, you should inspect the developing cylinder, he is magnetic and in some cases something like paper clip or other metal dirt can stuck on it and cause breakage or damage of drum surface.
I recomend you to remove the toner unit, vacume it and check for foreign materials, also rotate the developing cylinder and look for damages or foreign materials.
Hope that something of this will help!
Aug 24, 2011 | Canon imageRUNNER 400S Copier
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
My IR 400 canon xerox machine's copy is white
clean the toner unit and clean the scanner ,replace the drum and charger roller (p.c.r) and solve the problem.
and my name is gm prathap kumar guntakal,09573910647
Jan 06, 2011 | Canon iR330-400 PS Ver 1.0
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
I am own a canon IR 400 copier printer. it is persist of black copy for xerox. but printing is alright please solve my problem
Hello sir; When you make a copy, lift up the cover check the exposue lamp is on, if not replace it.
Aug 02, 2009 | Canon imageRUNNER 400S Copier
Canon Service Manual For Ir 400 Logo
490 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
