Question about Pride Health & Beauty
Scooter speed control
The tiller assembly is new. Everything works except the speed control. are there any reasons other than a duff pot?
  • Pride Master
  • 1,271 Answers
Hi, well besides a duff pot , looking at the wiring ,,,check the connectors..
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 11, 2015
gewiz
  • 1271 Answers
SOURCE: SCOOTER WON,T MOVE OR MOVES ERRATIC LED INDACATES
hi, ok that's sounds about right, the speed pot hat is attached to the throttle lever is normally about 5K in value.
Posted on Feb 19, 2010
  • 61 Answers
SOURCE: scooter shows
You will more than likely need a new speed pot but some are connected to the throttle pot as well so it could be that which is at fault. Could also be wiring or worst case, control box but this is unlikely.
Posted on Mar 18, 2010
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning colintaylor1957@hotmail.co.uk"
guru_fixya
  • 944 Answers
SOURCE: my scooter blinks 7 times indicating the speed pot
Please don't worry this can be easily solved.This is an error.Technically calling it has Flash Code #7
Flash Code #7 is caused due to Throttle Pot or Speed Pot Error
Click here to download the repair manual PDF.
Since the steps are diagrammatic,i will give you the PDF,Please follow the PDF.The solution is in page no 16.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 26, 2010
  • 692 Answers
SOURCE: will not go. ohm wiring
me tool time you checked or changed about everything but did you check the electric brake. Sounds like the brake is not working or is working intermittentaly. The controller needs to get the right reading from the brake or the scooter will not go and when you release the throttle the brake should engage immediately. I can't give you a well thats the answer but you should at least ohm out the brake. If you can call rascal Company on Monday and ask for tech support they can give you what the reading should be Hope this helps
Posted on Sep 18, 2010
Mobility scooter
The usual remedy is to replace both the tiller pot and speed pot at the same time. If your battery gauge is NOT dropping when speed is dropping then you need a tiller pot replacement as well. These parts have a typical 3-5 year life expectancy.
Oct 25, 2013 | Health & Beauty
George Freed, I don't understand the terminology, like whats a pod and where is is?? Thanks, Jim
I think the following is the post that is in question. I don't see "pod" anywhere in this text. However "pot" is mentioned quite a few times. Do you know what a pot is? Its short for potentiometer, which is kind of variable register when you turn it, it changes its resistance. What controls the speed of the scooter is the toggle throttle lever which are connected to pots. If you have anymore questions please feel free to ask. Be patient i just got my gull bladder removed, it wasn't fun.
You don't want to ever bypass anything on these scooters, doing so will either get someone hurt or silverly damage the scooter. There is a good reason your scooter is shutting down. The controller monitors the amperage flow, if at any time the amperage is to high for to long a period of time the controller will shut down the motor, so as you can see there is no sensor to bypass. Also the controller will send a code 4 failure out to a LED out on tiller head. There should be a lamp blinking on the tiller head when the motor is off line. The service lamp is cyclic, in this case the lamp to flash 4 times pause flash 4 times pause.
iT sounds to me like you have one or more shorted windings on the armature of your drive motor which is apart of the trans-axle assembly. TO BE SURE remove the entire trans-axle module. I have a Rascal 600t all i have to do to remove my trans-axle is to remove to quick pins and my entire trans-axle assembly comes away from the scooter. Take the entire assembly down to your local motor repair shop that can rewind motors. Thay will check out the motor, take it apart and clean all the carbon dust from the brushes that gets all over the interior of the motor, doesn't do the motor bearing any good. Rewinding a motor isn't inexpensive costing $200 and up depending on the size and complexity of the motor. But the scooter trans-axle cost is astoundingly high at $1,500 and up. They say they are sealed unit and that they can not be repaired. In reality trans-axles are quite simple to repair and easily repaired. The only difficult thing are the scooter companies that will not come across with the parts and info we need in order for us to keep our scooters in good repair. So ii'd take the trans-axle down to the motor shop. They don't charge anything to check it out. When they do maintenance you will know its working right. When troubleshooting problem with scooter you eliminate half the machine when you eliminate the trans-axle. Get back to me once you've checked it out
If you want to do a check of the trans-axle your self. You can do this by blocking the drive wheels off the ground. Turn the speed pot to
slow. Just give the motor enough power to just move the tires very slowly. Does it take allot of throttle to move the motor. Could be stiff bearings. Does the motor stall out. Hook an amp meter in series to the motor, run the motor real slow. Does the meter needle bounce around allot. If it does that means the winding are not so good. Now floor scooter. Does the trans-axle get hot. There usually a brake assembly at the end of the motor. When you start or stop the motor put your fingers on it you should feel it engage and disengage. Is that brake dragging, does it get hot. This brake assembly gives me lots of grief, drying out it gets stuck. WARNING never use WD40 it eats certain plastics and gets gummy. I use pure silicon oil spray. Hope this helps.
Aug 09, 2012 | Pride Mobility Products Go-Go Elite...
Mercury M48 scooter cuts out while driving
check the throttle pot. it is just a variable resistor, look online for a video, could have corrosion or carbon buildup on pot. also test the speed pot same issues
Apr 10, 2017 | Drive Medical Health & Beauty
Scooter will not move & the troubleshooting light does not work.
First with this kind of problem the easiest thing to do is to pull the trans-axle from the scooter and take it to a motor shop for testing. If it needs anything they will find it. Anyway you will have a known good unit. Next its best to check the engager in the tiller. To test the engager you will need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Testing
1 Remove any covers in order to expose engager lever assembly.
2 Check the resistance of the two outside terminals of the engager potentiometer with the multimeter, the reading should be 2.5kohm +/- 200 ohm
3 Slowly squeeze the lever, the needle on the meter should slowly and smoothly drop to zero. Do this same test for the reverse side too. If the meter doesn't move smoothly clean the pot, if the pot is out of spec replace.
To test the controller get both drive wheels off the floor. Make sure the speed pot which is also located in the tiller and is a separate pot from the engager. is set to zero ohms. At the controller output to the motor use the meter to take the DC Voltage measurement. Pull the engager lever to full forward. The meter should ramp up close to 24volts. It won't do this in reverse. If it fails to reach 24 volt use the meter to do continuity checks of the wiring from the speed pot and engager to the controller there should be zero ohms on these connections. Its not difficult to chase wires. What goes into a cable harness comes out somewhere! To do a continuity test you set the meter to the highest ohm scale. Short the test leads together, the needle should deflect. Calibrate the meter to zero by using the zeroing knob or adjustment. Now take a test lead go to the speed pot, place the test lead on to the pot terminal. Trace the wire hooked to the speed pot terminal to its connector plug. Take a measurement from the output side of the connector, not from where the wire goes inti the connector this way we test the connection too. If you get resistance pull the connector apart put it together again\retest, All the stuff in the tiller run into some sort of cable that either plugs directly into the controller if your lucky. If your not lucky and i wasn't the cable runs into the main harness [ the rats nest]. Here you must use s little logic. The lines we are looking at are control lines generally speaking really slender usually around 22 awg. Power lines are way fatter usually 12 to 14 awg. So you right off know that if you got a 22awg wire input you will have the same output. The controllers connector blocks are arranged by function. You can bet
connector blocks with 12 awg wires are for power skip them you normally don't have to look at those blocks. The controller line blocks are usually smaller. Leaving the test probe at the speed pot terminal use the other probe to check out the wires going into the controller one of them will show continuity... Simply unplug the block connector, WARNING look for lock-down devices. touch the pin with the probe.. Make a pin-out chart by labeling the controller blocks A threw whatever. Every connector gets a letter. every letter gets a column on paper . Every wire gets a title [ what does this wire do] which is listed at the far left make rows to the right of the tittles. So if the signal your chasing starts at pin 1 connector A and ends at pin 6 at connector C, you can easily list under wire title. By this method i've got a full pin-out of my scooter. Hope this helps
Jul 17, 2012 | Health & Beauty
Hi my scooter will drive in reverse on its own at all kinds of speeds if u leave the key on and is slow in forward only it will only stop in reverse if you turn of key or disconnect the forward or reverse...
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
May 02, 2011 | Health & Beauty
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Have a Colden Companion II; batteries appear to be fully charged yet cannot get anything out of the forward or aft levers. Bottom line, no movement whatsoever. Any idas
Model Well there could be problems in the tiller area or with the controller near the trans axle. A bad throttle pot can cause it not to move or a bad speed control pot or a bad cable to the tiller from the rear. Could also be a loose connection so check all your connections at the rear and in the tiller. Unfortunately with a scooter there is more that can go wrong than with a power chair and trying to fix over the internet is hard. You can contact your provider to see if they can check it out for you Might cost a little but at least you would know what the problem is. Sorry I couldn't tell you exactly what the cause is Good Luck Hope this helps
Sep 30, 2010 | Golden Technologies Companion II Travel...
Shopriderxl4 deluexe bogs down cuts out i have new batteries and show a full charge
Are you getting any kind of flash code on the tiller? It could be the throttle pot or speed control pot. If Medicare purxchased your scooter contact Repair Xpress at 1-877-581-3733 they have techs across the country and will bill Medicare. If Medicare didn't buy your scooter and you can afford it call them abnyway to have a tech check out the scooter for you Hope this helps
Aug 17, 2010 | Shoprider Mobility Products, Inc. Hero...
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
Oct 19, 2009 | Pride Mobility Products Pride Legend XL -...
My go go elite scooter suddenly dies seems to happen on the slow speed the control panel seems warm.
You might be over the weight capacity for this little scooter. When you overload it, the controller senses and overheating and slows the scooter down to prevent burning up the electrical system. When it has cooled, it will operate normally again. If you aren't overloading it, or if the previous owner did in case it's used, then the PC board needs to be replaced which is located inside the top of the tiller cover and the speed pot conects to this board. They aren't too expensive; about $30.00 from a Pride dealer. Take the shroud covering the tiller assembly apart by removing the screws that hold the clamshell cover together. Take the knob off the speed control and you will see an electronics board with several snap-on connections to it. This is what gets replaced.
Apr 17, 2009 | Elite Pride Go Go Traveller 3 Wheel
Health & Beauty Logo
102 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
