Question about Makita Drills
Makita hr1260 drill won't rotate. how can I fix it?
I put bits in and the drill switches on but won't turn the drill bits.
    Top Expert:
  • Makita Master
  • 42,555 Answers
Have an appliance centre check out the drill motor as it may be burnt out.
Posted on Jun 11, 2015
  • 14 Answers
SOURCE: makita core drill model8406
Hi the 8406 was common for the intermediat gear to go have you yet stripped the gear box?
Quick test wear gloves to do this!
Turn on the drill if the chuck does not turn spin the chuck with a gloved hand TAKE CARE!! if the chuck catches grip one of the gears are gone.
Hope this helps let me know. Sean
Posted on Mar 04, 2008
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
  • 9 Answers
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Posted on Dec 04, 2008
  • 100 Answers
SOURCE: Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Posted on Feb 16, 2009
SOURCE: Need to Replace Makita Drill Switch
i am loking for a swich for my makita cordless drill model 6010D DC7.2V SER.NO 4535837E HOW CAN I FIND DAT?
Posted on Apr 05, 2009
How do i put in a drill bit in ryobi 500w impact driver
hold the black part of the chuck with one hand and turn on drill with a bump and the chuck will open. then insert bit. if you feel chuck not open reverse the switch and it will open.
Feb 01, 2015 | Ryobi Drills
Drill bit stuck in ryobi impact drill
Put the bit in a vise and try to turn the drill to release the bit. You will need to put a wrench on the area of the drill that's holding the bit and do the turning by the wrench.
Jan 12, 2015 | Ryobi Drills
Makita cordless drill
It sounds to me like the clutch is set to a low setting. Its the dial just behind the chuck with the numbers on it, you can turn it to adjust how easily the drill slips, the purpose of it is to make it easy not to strip screws or drive them in too far. Just turn it to a higher number or all the way and it should work fine. The setting its on is whichever number is on top of the drill (opposite the handle), there should be a little arrow on the body of the drill pointing to it. The highest setting will not be a number but an image of a drill bit, in this setting it will not slip at all. Some of these drills are also hammer drills (as the drill turns, the chuck will also "hammer" in the direction your drilling, this is for drilling into concrete and things like that and requires a special bit (if your drill has that there will be an image of a little hammer on the dial next to the image of the drill bit). I hope that helps, Good luck.
Apr 24, 2013 | Makita Lxfd01cw 18-Volt Compact...
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
I can't loosen the the sleeve that holds the bit and therefore I can't change my bits.
Stick the speed fix to 1, put drill in reverse, and hold on to the chuck as hard as you can, and squeeze the trigger.
Jun 07, 2012 | Makita 12 Volt Cordless Drill/Driver Kit
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
Remove drill bit from 18 volt drill
Put the dril in forward, hold the collar, and just bump the switch long enough to get the internal portion to turn. The bit will likely fall out at that point.
Keyless chucks are make in a way that each of the jaws have an exposed heel that can grab onto larger bits that were inserted too far into the chuck.
Feb 14, 2012 | Hitachi Drills
My bit in my drill is stuck into a large tree stump... that had been cut close to the ground. How can I get the bit unstuck? My dewalt drill is unable to drill in & drill out.
If it's a twist bit try putting a vice-grip pliers on the end and turn it so the fluting pushes the bit out. If it won't move or if it's a spade bit you'll have to split the wood around the bit. You may or may not be able to do this with the offending part of the stump in the ground. Using a wedge, drive it into the stump near but not next to the bit so you don't damage the bit. Don't drive the wedge flush into the stump or you may get the bit out and then have the wedge stuck. Worst case, carefully use a chainsaw to cut out the stump so you can split the wood around the bit.
Feb 01, 2012 | American Tool 6 each: Irwin Metal Drilling...
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
How do I open the chuck or drill mouth to replace the drill present in my DeWalt Heavy-Duty 3/8? Keyless Chuck Drill?
Hi Tony,
To remove the bit with a keyless chuck, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 19, 2011 | Dewalt Drills
Drills Logo
167 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
