Question about Belling Kitchen Ranges
Belling gas stove. One spark is very weak and sometimes does not spark at all. All the others work perfectly. What should I do to replair the defective ignition spark
  • smarchives44
    smarchives44 Apr 24, 2015
    additional: Three of the sparks are sufficiently strong to light three of the burners. In the fourth case the spark is very weak and only can be seen if I bring the metal cover near to the spark emitter. Clearly the spark is not strong enough. I have cleaned the spark node with a pin, and with spirits and dried it, also I have cleaned the metal edge of the ring. But none of this makes any difference.
  • Belling Master
  • 15,989 Answers
Check the igniter at night in the dark, don't turn on the gas. Look for spark intensity in the area of the gap and also check the wires for any flashing that shows their integrity is bad.
Posted on Apr 24, 2015
Testimonial: "Very helpful. I now know that the ceramic spark nodule will have to be replaced. Thanks Vladimir"
  • Brad Brown Apr 26, 2015
    I am not vladimir
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,745 Answers
Remove the gas cover and clean up the sparks' surrounding area, first with water and soap then dry it with cloth.
Testimonial: "Your advice makes a lot of sense. And thanks for it. I did what you said and it made no difference. So obstruction / dirt can be ruled out, perhaps. The spark produced has almost disappeared. Not strong enough to light the gas. All other sparks are perfect."
  • Vladimir Frolov Apr 24, 2015
    Then there's the only one thing that would cause such: a shortcut in the ceramic isolator of the ignitor. Then it's to be replaced.
We have just moved house and have been left a Belling Platinum Dual Fuel db2 Cooker and cant get the ignition to work. Can anyone suggest what we should do?
by cooker,do you mean a stove? is it gas?is the gas knob in the "on" position?is the stove plugged in?
i clean out apartments to get them ready for new tenants. if the ignition clicks on,but the burner isn't lighting,it might be dirty. i soak the burners in hot water overnight. scrub with a wirebrush.poke a needle in all the openings & on the ones in the stove. dry thoroughly & see if it works.
if the ignition isn't clicking at all,one of the components in the electrical box might be broken.i wouldn't mess with gas or electric.call your gas & electric supplier or a repairman to find out what's wrong & see if it's worth fixing or not.
Mar 30, 2015 | Belling Kitchen Ranges
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a gas stove/oven the ignitors to the top clicks but doesn't spark and the oven doesn't work at all?maytag performance
Number 13 and 22 is the parts I suspect.
13 is the ignitor which even if it glows could be weak, It must pull at least 3.5 amps to open the gas safety valve. The spark module(number 22) could also be weak and not putting out enough juice to light them burners. Seen it.
Sep 18, 2011 | Maytag MGS5770 Gas Kitchen Range
Ignition on hob not sparking
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Belling Solitaire G747 Gas Kitchen Range
No ignition on burner for belling
When you cleaned it you might have hit the igniter. The gap between the ignighter rod (the rod that the spark originates from) and pilot has to be at a certain width. Here's what you do. Look at a burner that works, take note of how it is put together, and adjust the broken burner assembly the same way. Especially note the space between where the spark comes out. Also, make sure all wires are connected. If the burner is not grounded, it will not make a spark. Check to make sure the wire to the igniter is connected. DO NOT TEST TO SEE IF IT SPARKS WHEN TOUCHING ASSEMBLY!!! Get back to me for more help if you need to. Take note of ALL you do, and what happend when you did it, the more info I have the better.
Mar 31, 2010 | Kitchen Ranges
Stove burner will not light. I hear and see
There are two things I would recommend that you do . Check your burner mantle in the area where the igniter makes the spark for a small hole . It is a pilot hole specifically for the igniter . Sometimes it gets clogged with oil or grease. If that's OK, I would suspect you probably have a weak igniter control module , and you'll probably have to replace it .
Mar 03, 2010 | GE Kitchen Ranges
Amana stove top burners click, and gas comes out, but won't ignite. It's a self cleaning ARG7200, about 11 or 12 years old. Oh, and can I lift this top? I'm used to doing that with old pilot-light...
A weak erratic spark from one or more electrode usually indicates a bad spark module. No spark from one of the electrodes while the others work properly usually indicates a bad electrode. Inspect the porcelain of the electrode for cracks, chips or burn marks. If there are any, the electrode should be replaced. If one of the burner knobs is turned to the light position and nothing happens, but all the others function correctly, the spark ignition switch for that one burner is likely bad. The switch can be taken out of the system and checked with an ohmmeter. It should close for continuity at the light position only.
Go here for:
Amana Range/Stove/Oven Parts
RepairClinic.com
appliance parts, help & more
Sep 21, 2009 | Amana Kitchen Ranges
Stoves 900GRa spark ignition
i have a 900g stoves oven how do you change from auto to manual
Nov 02, 2008 | Stoves Premier 900GRa Gas Double Oven
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Kitchen Ranges Logo
226 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
