Question about Bosch AQUATAK 110 PLUS Pressure Washer
MOTOR RUNNING BUT VERY QUIET LIKE NOT ON FULL POWER LEADING TO A LIGHT SPRAY SPRAY ONLY. SEEM TO BE NO BUILD UP IN PRESSURE
CLEANED INLET FILTER OK
4 Suggested Answers
  • 7 Answers
SOURCE: Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Posted on Aug 30, 2008
SOURCE: Bosch HWS will not start up . ie no flame. no
Problems can range from bad check valve to crossover in shower faucet, to bad PC board to tripped breaker. That's a pretty broad range.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open link below for a few self-help remedies and many resources; contact service technician and contact Bosch, read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual and suggested by service technician.
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 29, 2011
KevinWhite
  • 1902 Answers
SOURCE: Does not fill with water. Program light on. seems
Hello & Welcome to FixYa
The problem is with the water inlet valve that needs replacement. You can also test the valve before replacement, if the valve tests fine then the float switch located at the bottom of the unit needs to be tested and if bad it is recommended to replace it. Please get back to me if you have any other questions.
Kevin
Posted on Apr 27, 2011
Karcher K2.54M loss of all pressure
I have seen it before where the little plastic pistons overheat and melt. The unit still runs but with no pressure. I would pull the pump apart and check the pistons.
Sep 03, 2012 | Dishwashers
My dishwasher won`t start. NO light are open. The electrical power it's ok.
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Jan 27, 2012 | Blomberg DW 15140 Full Console Dishwasher...
When the trigger is released, the motor stops as it should like it has built pressure. When I depress the trigger the motor cycles like it can't build pressure. The pressure goes up slightly and backs...
only reason you would have scale build up from hard water in a chainsaw, is if you have water inthe fuel.this sounds highly unlikey ,but water in fuel will make saw run like ****
also the laquer build up from 2 stroke oil in fuel mix will make it run bad
spray some carb cleaner in it or have the carb overhauled
Dec 14, 2010 | Garden
Maytag Quiet Series 300 - it seems like the soap door is not opening and when it does the soap packets are not dissolving. I cleaned out all of the spray arms. That did not help. What else can I do??
  1. Be sure that you don't have something large blocking the dispenser door like a cutting board.
  2. Make sure the water temp is 125 degrees going into the dishwasher. Cold water won't break down detergent correctly.
  3. Make sure your getting water pressure: Run your dishwasher on normal. Wait until the cycle starts and the spray arms are spraying. Turn a cup right side up to catch water on the top rack if you run the dishwasher and wait 20 sec that cup should be half or full. If you don't have water in the cup you could have poor water pressure from your pump. This could indicate 1. Worn motor 2. Clogged pump
Have a great day!
Dec 07, 2010 | Maytag MDB7100AWB Dishwasher
1995 jetta 2.0 fuel pump pressure good,injectors showing pulse with test light,removed fuel rail and cranked motor, injectors appeared to be working,although seemed to be very small amounts of fuel (not...
ok could be a few things.
Have you changed the inline fuel filter? these usually have paper filter elements and after a while can be clogged with moisture which blocks fuel flow. The fuel pump will still have good pressure but the fuel rail will lack the flow required and you may burn out an injector as its running too lean. Secondly, the MAF sensor, could be dirty, clean it with electrical cleaner.
I think its more likeylt the fuel filter blocked. Try and bypass it if possible, reset the ECU and try agiain
Mar 06, 2010 | 1995 Volkswagen Jetta
Wagner Paint crew - No pressure
In order of likelyhood:
1. There is an inlet valve where the paint first enters from the hopper. With the machine off, you can poke your finger all the way down the hole. It's spring loaded and will depress abouta quarter inch. If the inlet valve is stuck no paint will pump in PRIME or SPRAY position.
2. In SPRAY position. Motor runs for a few seconds then turns off. This means the pump is working. When you pull the trigger, if you get poor pressure, the problem is in the gun. Unscrew the handle and remove the filter. Clean out everything you can, and replace filter if necessary. Also try turning the spray nozzle 180 degrees and spray to clear if necessary.
there are more things that can go wrong, but these are the most likely.
Jul 08, 2009 | Air Tools & Compressors
Power loss with Focus TDCI 05, Turbo Problem?
Fucus 2005 tdci ESP light comes on then dont want ref over 3000rpms.
Apr 22, 2009 | 2005 Ford Focus
Kenmore built in dishwasher~2001 model year ,noisey when running.
HI remove the spray tube. remove top cover. look inside that could be a broken piece. this patr can break with pieces of glass going through it. thanks
Oct 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Bosch AQUATAK 110 PLUS Pressure Washer Logo
59 people viewed this question
Top Bosch Garden Experts
roeb
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
