Our air conditioner keeps going off, and won't come back on, what is the problem?
Our air conditioner has quit 3 times in the last couple of weeks. Each time the landlord sends a guy out, and he only spends a couple of minutes, and "fixes" it. The first time he said it was a fuse. The second time he didn't say what it was, just "try that and see if that works". It happened again last night, and this time we noticed that it quit after turning the dryer on. We also remembered the second time it quit, we had turned the dryer on that time too. What would cause this, and what is the problem? We checked the breakers, and that is not the problem. We have a gas furnace and air. The air or heat won't turn on at all. There is no power going to it. I wish I knew what it was, so that maybe we can "fix" it ourselves, because last time we waited 3 days for the guy to come, he kept saying he would be here, and we would wait all day, and can't plan to go anywhere. Anyone recognize this problem?
  • ltravis1446 Apr 22, 2015
    Could turning on the dryer just be a coincidence? Because I have googled the problem and can't find anything.
    Master:
  • 369 Answers
Does the dryer still wor? you can try switching off the circuit breaker then back on in case the ac is locked out electricaly. do both the dryer and the ac breakers, but this would not be common to two circuits which should be independent.
Posted on Apr 23, 2015
  • Jorge Rosado Apr 23, 2015
    P.S. You may need to reset both indoor and outdoor power if your ac is split system
2010 Mazda 3 power steering quit warning light is on
Could be the power steering pump is bad.
Dec 06, 2014 | 2010 Mazda MAZDA6
10 months ago I had my 6 year old Dometic A/C replaced by a friend who bought the new unit directly from Dometic via a Dometic employee. It worked fine the two times I use it this past winter while...
10 months ago? Do have any warranty on this?
As far as adding refrigerant. Yes - you can add some - but you need to fix the leak first, since it will be quite expensive to keep putting refrigerant in. I would first try to get the mfc repair it and if that fails I would call a serviceperson.
note: fixing a leak and re-charging the system is going to take someone 'very' knowledgable of air conditioners.
good luck!
Jun 13, 2011 | Dometic Rooftop RV Air Conditioner
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
My A/C was serviced last week and it was fine until last night when the cooling is not enough again
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 15, 2011 | LG Heating & Cooling
2004 Saab 93: A/C doesnt turn off, car now wont start
remove the AC relay to shut the AC off all the time. Not sure why it wont start but you may havea security lockout. Fully charge the battery to proceed.
May 31, 2010 | 2004 Saab 9-3
Carrier Air Conditioner- not reaching set temperature
if it is set to 76 degrees and its 78 in the house its working fine it is suppose to shut off once it reaches 76 but sometimes there is a 1 or 2 degree differential built ini would keep you filter clean and as long as it blows out cold air i wouldnt be to concerned most airconditioners need yearly cleanings though
Jul 14, 2009 | Carrier 38CKC036 Air Conditioner
Amana air conditioner keeps popping its cord breaker
This a ground fault breaker. They do go bad. Is it kicking it all the time or when you plug it in. I replaced a lot of the ground fault plugs. You have to go to the Appliance Parts store to get a new power cord. If you have a problem with thisyour warranty should cover the power cord check your warranty. Rus
Jul 11, 2009 | Amana ACB065R 6000 BTU TOUCH/REMOTE ROMM...
Outside a/c fan quits but compresser still runs
it sounds like the fan is over amping itself and shutting down on thermal overload check the amp draw during running time and compare it to the sticker on the outside panel it should be running .9 amps, and it will over heat if it runs around 1.2 amps or above
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Air Conditioner in 03 Toyota Echo
apology in advance, still waiting for the details from your repair bill.
Sep 24, 2008 | 2003 Toyota ECHO
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
