2 orange light flashes after spin cycle and stops
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for any blockages
Posted on Apr 26, 2015
It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Aug 17, 2015 | Fisher and Paykel Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Bosch WFO2865GB that stops before the Spin cycle
probably not draining fast enough, check for blockages at filter, sump, outlet and plumbing
Mar 29, 2010 | Bosch Washing Machines
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Fisher & Paykel GW703 wont stop!
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Oct 07, 2007 | Washing Machines
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
