Question about HP OfficeJet J4580 All-In-One InkJet Printer
Scan to pc works but copy do not
Since yeterday, first my scanner got struck on right side and would not move from their, but luckly when i took it off and try at home it worked. now, i can scan doc to pc from feeder but they is two straight dark lines, print copy is working from pc, fax i havent tried it since the issue, but the copier in colour or black isnt working. when i put the paper in feeder or flatbed, it will scan few first lines and goes white. i tried again but without any paper to check if the scanner still moving, which it was. what could be problem for getting two dark line when i scan to pc, and copier (without pc) not copying after few lines each time. the scanner light is not stable, it turn on and off
MUKHTAR
  • 2017 Answers
SOURCE: All copies and scanner outputs result in a totally black image
i is problem with your scanner if you ablt to open it and just apply little bit servicecing for your scanner head rod or ypy can show it service peronnel.
bye
Posted on Oct 16, 2007
MUKHTAR
  • 2017 Answers
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Posted on Nov 30, 2007
Khalsa007
  • 79 Answers
SOURCE: Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Posted on May 27, 2008
  • 53 Answers
SOURCE: Lines print on copies when put through the scanner. But do not appear on copies when placed on the glass
You may also want to check if the ADF is dirty or contaminated with dust or hair. Here's a link with some information about how to clean the scanner:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=1&ccs=229:1:0:111:0:0&mode=DOCS&doctype=KB&term=Scan%20Copy%20Quality&docid=ENUS32544
Posted on May 19, 2009
  • 102 Answers
SOURCE: thin black line appears on all copies ONLY from form feeder
Hi sounds like you have a particle on the window in the feeder. What hapens is when the light scans the paper your copying the particle of dirt shows up as a line. Simply clean it with a soft cloth and mild window cleaner. . Thank you for using Fixya.com
Posted on Feb 09, 2010
I have a canon pixma MP495, can't get it to scan. I've installed the driver from the canon website, but still no luck scanning. it worked before not too long ago, but now it won't
if you can print but cant scan, your usb is ok. so its either your pc or your scanner machine has the problem. to isolate the scanner machine if it has the problem, try to scan with the lid or scanner cover is open. observe if the "stick" (with the lights and belt attach to it) can move around the glass (left or right or up and down, depends on how you look at it). if its stuck in one side, then you have a mechanical problem. otherwise, check for your pc for some problem. you can check it by installing the printer driver to a 2nd computer and see if that pc can scan or not. if that 2nd pc cant scan too, definitely your printer is defective
Sep 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
I cant copy or scan because the message scanner lock error
The scanner which moves left to right underneath the glass is either stuck or has gone bad. Turn on the machine with the top cover open and see if the scanner moves all the way to the right and then to the left. Good luck.
Jul 14, 2011 | Sharp AM-900 All-In-One Laser Printer
I have a lexmark x560n printer. It will print from computer perfectly but when I scan or copy something the right side of the copy has the ghost image while the left5 side is perfect? Whats up with this?
Something is blocking the scan light. Dirty glass or something like that. Check the scanner glass and the scanner lid.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Oct 07, 2010 | Lexmark X560n Laser Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
Network scanning problem
scanning from any device is simple you need three things
   user name   bill    password    piguine    path            \\server\scans\shared folder
the scanner needs rights to write to  a folder on the network..  good luck
Apr 27, 2009 | Samsung Office Equipment & Supplies
Scanner bar will not move to scan the paper to be copied.
a piece of plastic locks your scanner in place, it is under the scanner up above where the copies come out. It turns 90 degrees.
Maybe some one turned and locked it.
Good luck
Bob
Apr 23, 2009 | Sharp AL 1631 Copier
Trouble scanning without pc
Using the operator panel:
  1. Turn the printer on.
  2. Open the top cover.
  3. Place the document face down in the lower right corner.
  4. Close the top cover.
  5. Press the Color or the Black copy button as required.
Using the computer:
  1. Make sure the printer and your computer are turned on.
  3. Place the document face down on the scanner bed in the lower right corner.
  5. Click Start, Programs, Lexmark Xx3, Scan & Copy Control Program.
  6. Select the number of copies.
  7. Click the option that matches the desired color of the copy.
  8. Click the Copy button.
To customize the copy settings:
  1. Click Start, Settings, Lexmark Xx3, Scan & Copy Control Program.
  2. Click File and then Setup.
  3. Select the Copy/Fax tab.
  4. Customize your settings as required.
  5. Select OK to start copying
Apr 04, 2008 | Lexmark X73 All-In-One InkJet Printer
Scanning trouble PLEASE HELP!!!
1. does scanning from the pc looks good ?
2. printing photos from the pc looks good ?
3. does standalone copy (placing image on the scanner bed then pressing the COPY button on the printer) looks good ?
Dec 31, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
HP OfficeJet J4580 All-In-One InkJet Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
