Question about Toshiba E Studio 2330c 2500c 2820c Copier Drum Kit
Bad color toshiba e-studio2500c color photocopier
The image was good until i bought a new cartridge then I found the Image has been faint for ex the red color becomes orangeeven though the cartridge is catton i bought it by 1600 LE now How can i adjust the color contrast please any program or any way to me ..thank you
  • 700 Answers
SOURCE: Toshiba TV Red Color turns black and regains after a long time
If this is a crt type, it could be a loose connection. Check its RGB board usually located at the backend of the crt tube. Dust, cobweb, carbon built up might be the one causing it.
Posted on Apr 18, 2009
  • 10 Answers
SOURCE: Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Posted on Oct 19, 2009
Testimonial: "Thankx Alot Man"
SOURCE: I can not find any contrast controls on my Toshiba
There isn't any contrast controls on TFT screens, it's color response depends on the maker of the panel.
If your PC has a Intel or NVidia graphic card, you can modify some color settings from the video driver like gamma or contrast. For NVidia cards, there is a setting called "Color Vibrance" or "Digital Vibrance", increase that.
On Intel cards, right click on the desktop, go to graphic properties, color correction.
Posted on Nov 04, 2009
projdoc
  • 2236 Answers
SOURCE: I have a Toshiba TLP-S30 and lately the color
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Posted on Nov 11, 2009
SOURCE: My Toshuiba 46RV530U tv has developed an image
The only solution is do not buy a Toshiba. They do not support their product.
Posted on May 26, 2010
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
Prints come out with faint horizontal "stripes"
run the nozzel cleaner and other test its in its software menu ok download latest driver from website also
Jan 30, 2008 | Epson Stylus Photo R800 InkJet Printer
Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Mar 19, 2012 | Office Equipment & Supplies
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
One cartridge which is new will not print
If the printer tries to print but there is no image then it is possible that the sealing tape on the cartridge has not been removed. If the printer does not even accept the cartridge then it is possible that you have a bad cartridge. Put your old cartridge in to confirm that printer is good. If this new cartridge was not an original HP cartridge then there is a pretty good chance that it is defective and the company you bought it from should replace it at no charge.
Mar 18, 2011 | HP Color LaserJet 2600n Printer
Residual image on DC12
Not sure if this is what you mean but it is normal for this machine to leave a faint residual image particularly noticeable on heavy weight glossy stock with high toner coverage. I found that it shows up on black the most. I reduced this by rubbing with a soft cloth after printing. You will also notice that the image becomes less noticeable after the oil evaporates. There really isn't a fix for this, it is the nature of the machine. Hope this helps.
Dec 24, 2010 | Xerox DocuColor 12 Printer
Refilled cartidges not working, colour cartridge produces faint image, nothing when printing with black?
you have a goggled cartridges due to bad ink quility
or bad refilling process you must **** all air bubbles from the cartridge after refilling it
chech here the right process for a success refilling
http://www.youtube.com/watch?v=dhDaKSzou50
and for color
http://www.youtube.com/watch?v=II9gpIXs_lE
Dec 08, 2009 | HP PSC 1350 All-In-One Thermal Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Photocopying
According to " HP Officejet R, PSC 500 and Color Copier - General Copying Issues and Solutions", under the problem heading "Black is not Black", notes that:
"The unit will perform mono (or black) copies using the color cartridge to create a composite black in Normal and Best modes. This is necessary to create the correct grayscale shades. NOTE: The HP PSC 500 all-in-one product cannot perform black copies. Scan the image in and print it out in greyscale.
The color cartridge may be out of one color of ink. Run a self-test page to verify that all the colors are there. Replace the cartridge if they are not."
In other words, the device only uses the black ink cartridge when used as a computer printer. When used as a stand-alone copier, it uses the color ink cartridge, and all three ink colors must be present and working to give a black and white copy. Perhaps you can refill the color cartridge with black ink in all chambers?
Nov 13, 2007 | HP PSC 500 All-In-One Printer
Toshiba E Studio 2330c 2500c 2820c Copier Drum Kit Logo
61 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
