It ignores the times set and just comes on at odd times
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
I would suggest verifying the programming times and temperature settings. It is easy to get a bit confused and get one or more scheduled events wrong. I still have a problem programming some of these things on occasion and I have more than 38 years in the industry.....
Posted on Apr 28, 2015
Why does my G16 gas golf cart whines when the accelerator is pressed down but will eventually start after pressing it 4 or 5 times and it seems to help somewhat if I press it at the top which is odd???
yamaha g16 gas golf cart
time for a service and cant be ignored
something not right between pedal and drive wheels
if pedal has to be pressed like that
Jun 08, 2016 | Cars & Trucks
Sony experia m my phone doesn't want to update my watsap, just says my date an my time are incorrect whAt must I do?
it means that your date and time setting are not correct. But sometime that error appeared even when your date and time setting are correct. If so, just ignore it for a day and it will be okay, but make sure you have the exact correct date and time first before ignoring it. FYI: Just using auto date and time doesn't mean your setting is correct the auto can be wrong sometimes
Jul 15, 2014 | Cell Phones
Indicator lights on dash
the check engine light is on, but it was on a long time before this issue occurred.
Jun 13, 2014 | 2007 Suzuki XL-7
How To reset EFO code
Hi. EF0 is suggesting an internal leak which operates a float switch inside the cabinet at the base. It could be a leak (split door seal, hose, etc) or over-foaming causing a momentary leak. Dry the base and inspect. A blocked condenser on the dryer can cause the drum to overfill on wash. I have also witnessed the code come up when the drain pump is jammed..odd as this should be E20. If it drains ok ignore that!.
May 25, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
I cant receive mms
The phone has a 4-way directional 'Navi' key and 2 soft keys on either side of this and 4 additional soft keys either side of the keypad. The Navi key can also be pressed in to select options.
1. Select 'Menu' (press Navi Key).
2. Scroll to 'Settings' and select (press Navi key).
3. Scroll to 'Configuration' select (press Navi key).
4. Scroll to 'Personal configuration settings' and select (press Navi key).
5. Press 'Options' (left softkey) highlight 'Add new' select (press Navi key).
6. Highlight 'Multimedia msg.' and select (press Navi key).
7. Highlight 'Account Name' select (press Navi key), enter 'giffgaff MMS' then 'OK' (press Navi Key).
8. Highlight 'Server address' select (press Navi key), enter http://mmsc.mediamessaging.co.uk:8002' and 'OK' (press Navi Key).
9. Highlight 'Use preferred access point' and select (press Navi key), highlight 'No' and 'Select' (press Navi key).
10. Highlight 'Access point settings' and select (press Navi key).
11. Highlight 'Proxy' select (press Navi key), Highlight 'Enable' and select (press Navi key).
12. Highlight 'Proxy address' select (press Navi key), enter '193.113.200.195' and 'OK' (press Navi key).
13. Highlight 'Proxy port' select (press Navi key), enter '8080' and 'OK' (press Navi key).
14. Ignore 'Data bearer' as this is set at 'Packet data'.
15. Highlight 'Bearer settings' and select (press Navi key).
16. Highlight 'Packet data access point' select (press Navi key), enter 'giffgaff.com' and 'OK' (press Navi key).
17. Ignore 'Network type' as set at 'IPv4'.
18. Ignore 'Authentication type' as set at 'Normal'.
19. Highlight 'User name' select (press Navi key), enter 'giffgaff' and 'OK' (press Navi key).
20. Highlight 'Password' and select (press Navi key), enter 'password' then 'OK', verify password and again select 'OK' (press Navi Key).
21. Press 'Back' (right softkey) 6 times to get to the main menu.
22. Highlight 'Messaging' and select (press Navi key).
23. Scroll to 'Message settings' and select (press Navi key).
24. Highlight 'Multimedia msgs.' and select (press Navi key).
25. Ignore 'Delivery reports' as preset to 'No'.
26. Ignore 'Image size' as preset to '640x480'.
27. Ignore 'Default slide timing' as preset to '00:08'.
28. Ignore 'Allow multimedia reception' as preset to 'Yes'.
29. Ignore 'Incoming multimedia messages' as preset to 'Retrieve'.
30. Ignore 'Allow adverts' as preset to 'Yes'.
31. Highlight 'Configuration settings' and select (press Navi key).
32. Ignore 'Configuration' as this will change to 'Personal config.' with the next step.
33. Highlight 'Account' and select (press Navi key).
34. Highlight 'giffgaff MMS' and select (press Navi key).
35. Press the right softkey 5 times to get back to the standby screen.
The MMS settings are now complete.
Feb 07, 2011 | Nokia 6070 Cellular Phone
I want the Windows 7 Driver for Sansui SFL22MH TV/Monitor. Pl. tell me the location to download or send me the file.
ignorant untrue answer. Many monitors and especially older TV/Monitors of odd makers (Sansui for a FACT) are NOT plug and play and windows has no idea what resolutions it supports. Really, all you can do is go under advanced in your adapter settings and try different resolutions and refresh rates. If you can't see - quickly hit escape. Find the best one that works for your monitor.
Aug 07, 2010 | Sansui HDLCD3200 TV
Lost my manual for the NP 105CR Model Next Play IPOD Dock cube. Can't figure out how to turn off a radio alarm which comes on at odd times.
The Alarm is controlled by the Set button. Press Set once, then press Function to cycle through Alarm 1 functions until the display reads OFF. If needed, press Set again, and press Function until Alarm 2 also reads OFF. Press Set a third time, and you can set the main time with the Vol +/- (minutes) and the Skip (hours) buttons. Press Set a fourth time to return to normal display.
Dec 21, 2009 | Starlite Next Play Clock Radio with iPod...
How to change the battery in train 512
Hi Tarja, your question is 4 years old, but here is the answer:
You've probably seen the odd shaped tiny screws on the underside of the train. Ignore them - they require specialized tools and only lead to the wheels and gears.
You just need to insert a small cross-tip screwdriver into the exhaust funnel of the engine and remove the screw completely. The black front of the engine comes off and reveals AAA micro batteries which you gently shake out of the engine and replace.
As ever so often - once you know how to do it, it is very easy.
And - no, I didn't find out myself either *grin*
Nov 08, 2009 | Brio Mighty Red Locomotive
Q key keps printing
Understand and use (or make sure they’re turned off) keyboard Accessibility Options. There are several types of help for those with typing difficulties, namely:
StickyKeys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneously.
FilterKeys: You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally.
Bounce Keys: If you bounce your fingers on keys inadvertently, Bounce Keys will ignore repeated keystrokes until some time has passed. You choose the time period.
Repeat Keys and Slow Keys: The computer will ignore brief keystrokes according to the time limits you set. To access these Options and turn them off or on, go to your Control Panel– click Start >Settings >Control Panel >Accessibility Options.
By default it opens to the keyboard tab. If you are experiencing a sudden onset of bizarre typing behavior, your first step is to visit here and ensure that there are no checks in the three checkboxes, which indicates these Options are in use.
I mentioned that shortcuts ‘activate’ these features — such as Tab+Enter, and a couple of Alt+a letter– and so you may have turned them on unintentionally.
If you do have some difficulty with your typing, such as happens when a Mr. Arthur Itis comes to visit, or/and if you have tremors, here is where you can enable these aids and tweak their settings to get the most benefit from them. Click on the “Settings” button to see the choices. Below is the FilterKeys Settings dialogue.
In the case mentioned, my client had first held down the Shift key long enough to activate FilterKeys (because a finger “rests” there). The lady was an extremely fast typist, and this setting ignored her strokes as being too short. Since she has no use for this tool, I recommended that she uncheck the top checkbox and disable the activating shortcut.
This screenshot shows the settings for StickyKeys, and unless you have trouble holding down more than one key at the same time — such as Ctrl+Alt+Del to activate Task Manager — I suggest you uncheck the top checkbox here as well.
Aug 19, 2009 | Lenovo 3000 C100 Notebook
Heating & Cooling Logo
273 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
