Question about Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0
Why is the power light white? - Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0
  • Official Brand Answer
  • 3,100 Answers
Thor
Visit Home Arris Surfboard
Mark
Motorola Support
Posted on May 04, 2015
Where does neutral wire go at end of circuit?
If there is only a white and black and ground coming into the box from the fixture then that white is probably really a black. The black is hot, meaning it has power. The white takes the power back to the light. If you can open the light fixture box and see what wires power the light.
Jan 11, 2016 | Lutron Maestro 150-Watt Multi-Location...
Tip
Regular switching and switch loops
A switch loop is a technique that is often used in home wiring to cut back on wire used and to make the circuit less complicated. In a normal switching circuit power comes into the switch box with the white wires tied together and black wires on the switch and then continues to the lighting box where black is connected to black and white is connected to white. With a switch loop the power starts at the lighting box in the black wire that does not go to the switch. That black wire is connected to the white wire that goes out to the switch (note the white wire must be taped with a small piece of electrical tape to show that it is now a powered wire). At the switch both black and white wires must be connected to the switch (the white wire here must also be taped). So now back at the light box you should have two wires. A white wire from your incoming power cable and a black wire from your switch cable. Now all you need to do is tie black to the black of your light and white to the white of your light (note: if you have terminals, white goes to the silver terminal and black goes to the brass terminal.) The wiring is done in this manner because in electrical work black and white make a light, and the the colors are never mixed up because it allows the next person to diagnose any problems much easier.
on May 19, 2010 | Electrical Supplies
My back up lights burt out and wanted 2 know what runs off the same harnest or fuse for that I have a short
Hello! The back up light circuit is stand alone...Power is fed via the back up light switch to both the left and right lamp on a Red/White wire...Ground is fed by a White/Black wire...The back up light switch receives power from a 10 a fuse ( Gauge Fuse) on a Black/Orange wire... So, 12 volts from the gauge fuse on Black/Orange...through the switch on a Red/White to both back up lights...Ground to lights via a White/Black...Using an ohm meter with power off...Set on X10 scale...check the Red/White to ground...It must read open...if you read any resistance on that wire it will blow the fuse...Guru...saailer
Apr 26, 2012 | 1995 Toyota 4Runner
Motion sensor light wiring
problem could be sensor, not light, black is power, white is neutral, green is ground, sensor may have a red wire, black wire and a white wire, hook black wire to power from sensor, red to black wire on light,
white wires will connect together, then wire black to power on home, white to white on home and green to ground, if you need help call an electrician and they will wire it for you
Feb 03, 2012 | Home
I have got one power cable going to a 2 gang switch and need to feed two seperate lights off it.
Hello.
All whites are marretted together,
  • white power - white 1st light - white 2nd light
Blacks are the return for each light, and are joined after passing through the switches,
  • black FROM 1st light - top of switch - bottom of same switch - black power AND other black from 2nd light (see next step)
  • (repeat of above) black From 2nd light - top of 2nd switch - bottom of 2nd switch - black power AND black from 1st light
NOTE: both switch blacks are marretted together to the black of power. Ground all 3 as normal to dblgang box. Total marrettes required is two (three if using one for grounds) Hope this helps. If so, please rate a four-thumbs up, Thank You.
Apr 02, 2011 | Home
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Dec 06, 2010 | Electrical Supplies
How do myou connect a 110 motion light
The motion light comes from the store with a neutral (white) hot (black) wires. If there are multiple light bulb sockets on the motion light, the black wires will be connected together and the white wires will be connected together. There will be a motion sensor that has a red, white and black wire. The red wire is connected to the black wires from the bulb sockets. The remaining white and black wire from the sensor switch are connected to the line power from the panel. you must remember that all white wires from the entire project are to be connected together.
Most motion lights feed the line power from an independent switch that connects the power to the motion light fixture. Remember never to connect the white conductors to any red or black wires, as this will create a ground and you will continue to trip your circuit.
I hope this has been helpful.
Aug 15, 2010 | Home
I'm replacing a single pole light switch with a timer switch and the timer switch comes with a hot (Black) and a Load (Red) as well as the netural (White). My question is how to wire it up. Does the white...
It all depends on how the light on the pole is wired. The switch you have is meant to interrupt the power between the circuit breaker and the light, just like the switch does now. The new switch uses power to run itself, so you need an additional wire. Usually the lights on a pole have the power coming in on top, and a wire coming down for the switch - black and white. Lets say there was no switch - on top of the pole there would be a black wire going to the hot, or center contact on the pole light, and the white wire would go to the ground, or outside of the bulb. If (BIG IF) things are wired like they are supposed to be, there will be a black wire (hot) coming in from the breaker, down the pole, instead of going to the light. The switch you have in place now interrupts the power so you can turn it off/on. Then when you turn the switch on, power goes up the white wire to the hot, or bottom of the bulb. Theoretically, there should be another black wire going back up to power the light once it leaves the switch. People normally use regular wire, which has a black and a white inside a plastic casing. So, bottom line - you need to run a red wire from the light to the new switch, hook the white wire up to the ground. So: power coming in on top goes down pole to new switch to black. Red wire hooks up to pole light where it is now white, goes down pole to red on switch. Old white wire gets unhooked from light on top, and hooked to common (ground) on top.
Aug 31, 2017 | Globe Electric Globe Indoor/Outdoor Lights...
WIRING DIAGRAM
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Bought a hunter remote and can't figure out what wires to connect
The remote red wire should go to the black wire that goes to the light. The remote black wire should go to the black or black with white stripe wire to the fan. The white wire should go to both white wires from the light and fan.
The power in (black and white) should be connected to your power source black and white. Bare copper wire to ground on fixture
Jun 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Arris Sb6141 Surfboard Cable Modem Sb 6141 Docsis 3.0 Logo
423 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
