Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
  • Steve Harris
    Steve Harris May 10, 2015
    Hi Benson Tiyago, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Did you put the fan in yourself? Do you have turn the correct way?
    Problem Solver:
  • 9 Answers
Hi Benson.if your fan connector doesn't have the amount of pins that Christopher mentioned your motherboard will not detect it even if it's functioning properly. To disable such notifications you will need to go into BIOS and search for the CPU fan. You might be able to find it. If not look for a BIOS update which might fix the issue. Another thing you can try with the BIOS is to reset it, easiest way is just to remove its battery. After 30 secs put it back, boot up your PC and let the BIOS detect the hardware again. Hope this helps.
Posted on May 13, 2015
Testimonial: "Hi Tony, I took it back to the service providers. They checked it and failed to fix it. They gave me another one which works perfectly with the same fan. Thank you for the suggestion."
    Champion:
  • 261 Answers
Most CPU fans are PWM (4 Pins)
Some motherboards can work with a 3 pin(Speed Sensor) CPU fan.
Some motherboards require a 4 pin CPU fan.
Since you have 4 fans, plug the 4 Pin fans to the 4 pin fan connections,
and the 3 pin fans to the 3 pin fan connections.
Try a boot.
We find using 40mm, 50mm, 60mm, 80mm, and 120mm fans to test, (because they turn at different speeds), makes any errors in the BIOS or motherboard obvious.
Posted on May 11, 2015
  • Computers & ... Master
  • 2,826 Answers
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
  • Benson Tiyago
    Benson Tiyago May 11, 2015
    Thank you for the response. I have since returned that motherboard and the supplier also failed to fix the problem. Yes, the fan was connected to the right socket. I got a replacement and it works perfectly.
  • 54 Answers
SOURCE: monitor
Reset the Cmos battery,check the RAM,check the smps or check the motherboard ground, I think you problem will solve.
Posted on Feb 16, 2008
Helping_Guy
  • 34 Answers
SOURCE: my 4-pin cpu fan is not running
check the power connection for your mother board and fan
Posted on Mar 09, 2008
  • 518 Answers
SOURCE: cpu fan noisy /chip fan fail
You must buy a new CPU Fan. You can get them HERE or a zillion other places on the Internet. You need a Socket 939 type fan that will handle your cpu speed. If you need help installing it, it may be in the manual. You can read the manual by clicking on the picture of your MB at the top of this post and then scrolling down.
Hope that fixed ya...
Geno
Posted on Apr 01, 2008
SOURCE: cpu fan noisy/chip fan fail error messages
I had tons of problems with these Asus chip fans. I asked Asus to deliver 12 replacements (as I had a lot of pcs at that time with the same problem) It worked well, but placing a tiny heatsink well glued to the chip worked well also, as long as one does not want to overclock the thing. It's true that the temp raised a bit, but it remained pretty much in the tolerance area.
Posted on May 21, 2008
nenalex2002
  • 134 Answers
SOURCE: ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Posted on Mar 28, 2009
Dear sir, my motherboard is amd athlon 64 socket 939.when i on the system then system is running but processor fan is not rotating.Finally after 25-30 minutes it automatically turned of and displays cpu...
It sounds like the cpu's temperature is raising over the safety level set in the bios so it switches off and displays the error!
to solve this either:
Your cpu cooler fan needs replacing
or
Your current cooler fan isn't connected to the correct socket on your board (check you're user manual, usually a .pdf you can download from manufacturers site)
or
Just try connecting your current cooler fan to the cpu and see if it turns on at all. If not make sure you replace it with one that is compatible with your system that can fit in your case
If the temperature has raised to a significant level the thermal paste could probably use replacing also, so get some thermal paste remover and thermal paste, and read in your motherboard user manual how to replace the cpu heat sink safely.
Sep 26, 2013 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Help -- CPU Fan Failure bypass or pinout?
Yep I have a link below you can order the correct fan from.
http://store.cwc-group.com/y4574.html
I had the same issue here, we have 20 offices all running Dells. These fans seem to be used only on dell systems.
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Hi, I removed my PC's motherboard from one case to the new one. after installing every thing when I turned it on, it displayed the message 'CPU fan power failure' I double checked the...
is the new cooler fan does not draw enough power from the terminals that supply the CPU fan. The motherboard is looking for a specific amount of power from the terminal and gives a warning of a failure when the current drawn is different from the specs. You could look at the old cooler to see if the current requirements are marked on it and then match that current with additional fans ETC to the cooler you are wanting to use.
Sep 01, 2011 | Computers & Internet
My lenovo T410 displays the words "fan error" when
It's better if you call lenovo customer care and ask them to get it repaired.
Jan 14, 2011 | IBM Lenovo ThinkPad T410 2518QCU Notebook...
Does not boot up, fans start, internet plugs light, clicks on and off.....seems this is a common problem for these machines, what is the fix?
Instructions
  1. When you press the Power button to start the boot process, the LED lights glow while the computer verifies that there is sufficient electrical power to activate the hardware.
    Effect & Solution: When you press the power button, the LED lights on the computer do not glow or the LEDs blink briefly and then stop. There is no sound of the fan or hard drive spinning, and the screen remains blank. The computer will not start if there is insufficient battery or AC adapter power.
  2. The BIOS queries various hardware components used for the startup boot process.
    Effect & Solution: When you press the power button, the LEDs glow but there is no fan or hard drive sound. The LEDs may glow briefly and then go out.
    Or
    The LED lights blink, stop, and then blink a second or third time, but there is no sound from the computer and the screen remains blank. The sequence of the blinking lights indicates a specific error code.
    Or
    A series of beeping tones is heard. The sequence of beeping tones indicate a specific error code.
    If a hardware component has recently been replaced, or if the PC has been jarred or shaken, there may be a loose connection to the memory chips or hard drive which prevents the computer from starting.
  3. The BIOS loads the basic input (keyboard) and output (advanced LEDs / display screen / boot drives) devices into memory.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, but then the boot process stops and a black screen - with an error message - displays.
    The boot check has detected a communication error or conflict with a hardware component that must be corrected.
  4. The BIOS loads the Windows operating system and starts the services that allow low-level control of all of the background operations.
    Effect & Solution: When you press the power button, the LEDs glow, the fan or hard drive sounds, are heard, the HP or Compaq Logo displays on a black screen, but then the boot process stops and a blue screen - with an error message - displays.
    The boot check has detected a hardware driver error or a software conflict that must be corrected.
  5. Control is transferred to the Windows loader to initiate the display of the advanced settings in the Windows environment.
    The Windows logo displays during this step.
    Effect & Solution: When you press the power button, the computer performs all the steps in the boot process, but after the Windows Logo displays, the moving Windows progress bar or the rotating cursor stops moving and the boot process stops.
    An error message may display on a screen with the Windows logo. In some instances, there is no specific error message.
    Or
    A black screen appears and the computer attempts to restart.
    The Windows self-check has detected a software conflict that must be corrected.
Jan 09, 2011 | Gateway GT4016 Desktop PC
With asus m4a785-m motherboard and amd phenom x4 9600b quad core cpu why does monitor displays a cpu fan error when fan is running full speed.
Hmm, I've never seen a computer give a CPU fan error. Maybe if the fan is really dusty it's clogging it up, try getting some canned air and spraying it out.
Dec 17, 2010 | ASUS M4A785M Motherboard
Intel D865GVHZ (Gateway Hazelton) motherboard system cooling fan
This fan error message shows up when the CPU fan is not plugged into the CPU FAN plug on the motherboard. The Intel D865GVHZ
motherboard has a total of 4-fan plugs so it is easy to plug the CPU fan into one of the other fan plugs that is not marked CPU FAN on the motherboard.
Apr 12, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Cpu high temperature problem
Overheating problem
Remove case side and clean all fans
remove fan from heat sink usually 4 screws or little clips
Do NOT remove heatsink stuck on with heat paste
clean vanes in heat sink replace fan
use stiff brush and vacuum cleaner to clean outside of power supply
vacuum out case include all vent holes
reboot computer should work ok
replace case side
Nov 29, 2008 | ASUS P5PE-VM Motherboard
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Computers & Internet Logo
235 people viewed this question
David Payne
David Payne
