Do i have to turn water off to disconnect a washing machine
Need to remove old machine to connect new one
    Top Expert:
  • Washing Mach... Master
  • 42,623 Answers
Normal practice plumbing is to connect the machine hoses to the wall taps
unless you have something different ,turn the taps off at the wall and unscrew the hoses
if your practice is to leave the wall taps on all the time ,when you start to undo the hoses there may a bit of water squirt out as that will be the pressure still in the hoses
Posted on Apr 22, 2015
Disconnect hot water pipe on washing machine
you need to shut the hot water off some were if you need to at the
hot water heater it's self
Apr 05, 2014 | Washing Machines
Need to remove and replace electronic water valve
First off unplug washer.
Turn water off hot and cold.
Disconnect water lines from valve.
Remove screws from top panel on washer then slide top panel off.
Remove connections on valve. Make mental note for what goes where. ;)
Remove valve.
Install new valve.
Connect wires.
Put panel back on and screws back in.
Connect water lines hot for hot and cold for cold.
Turn water on and check for leaks around connections.
Plug washer in.
Run a load!
Hope this helps.
Oct 26, 2012 | GE WBVH6240F Front Load Washer
Washer spins out but will not fill or agitate
You most likely have a bad timer. If machine is filling properly, then the switch is bad.
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Sep 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine stops half way through the cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 30, 2009 | Whirlpool AWM6100 Front Load Washer
Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Apr 09, 2009 | Frigidaire FWS833A Top Load Washer
Whirlpool 6th Sense AWM8123/1 error code FH
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.thank u....please rate it
Nov 28, 2008 | Whirlpool AWM8143 Front Load Washer
Error code on bosch washing machine wwwf 2000 3 flashes of prewash light
HI
Oct 13, 2008 | Bosch Washing Machines
I have error F:16 on my washing machine.its an excell 1400S express
HI Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Oct 12, 2008 | Bosch Washing Machines
I need to know how to replace the timer-mall on my Amana washing machine model #ALW780QAC
hi here steps Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Sep 12, 2008 | Amana Washing Machines
Changing timer in whirlpool washer model number LSR7010PQ2
two phillips screws on the front bottom of the control panel will release it.......pull it forward and flip it up...........remove the knob and by pushing in and turning counterclockwise.......then remove the dial to reveal the timer screws.....remove those and disconnect the wiring harness.....replace the timer and reinstall all parts......
Jul 28, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
