Question about Electrical Supplies
Someone put a tester on an outlet in my kitchen and they said the wires are backwards?
  • 152 Answers
Open the outlet boxes and see what wire goes to which side of the outlet. The black wire should go to the narrow slot side of the plug. Check ALL the outlets they may all be backwards or just one. Or that whole circuit may flopped in the circuit breaker box. The circuit breakers should all have black wires(or red) going to them.
Posted on May 02, 2015
I have a light switch in my apartment that controls both the light in the kitchen and power to both sockets of a dual outlet. How do I adjust the wiring so that the outlet is always powered? The wiring...
This is not good wiring option. It is not good to have light and outlet on the same switch without different fuse. I suggest to insert another little switch on light connection. Than you can have control of both. Or you must find main phase (hot wire) inside switch box. This will be always on for tester when you try different switch position. When you find this main (hot) wire, you disconnect one of another two wire (after you disconnect power), than give power on and test light and socket (one of them will not work). If this is outlet, you must connect this wire to main (hot) one. Don't work when power on. Just test it with tester, and than disconnect when you change position of wire.
Good luck and be careful!
Aug 26, 2011 | Electrical Supplies
Problems with a GFCI outlet (no voltage). GFCI outlet was replaced and reset recently but that didn't fix the problem. One other GFCI breaker in the same room is working OK. Also, water is entering...
if your room is powered by one breaker you need only one gfci and it has to be hooked up correctly to protect the other outlets a new gfci will have a tape tag over the out side usually the top set of nuts the water in the panel is a major fire hazard i would fix this problem first your feed to the gfci may have shorted out in the wall between the breaker and the gfci if it is wired separate from the other gfci in that room one thing you can do to save calling an electrician is go to lows home depot or any electrical store and purchase a plug in tester they are inexpensive and easy to use it will tell you if wires are hooked up correctly backwards or if you have a short somewhere in the line this is the same little gadget that an electrical inspector uses to make sure new homes are wired correctly an outlet will still work even if some wires are incorrect in the circuit the outlet tester confirms all is good and safe
Jan 23, 2011 | GE Hammering
Slight tingle when I touch case. Noted that it only uses a 2 pin plug
This is wrong, and could be dangerous. It could be caused by a faulty device, or by faulty wiring. You owe it to yourself and your family to check. I suggest you purchase an outlet tester (or ask around your friends, someone might have one) which looks something like this:
Plug it in to the outlet and ensure that both orange lights come on, but not the red one. While you're about it, check every outlet in the house... it's worth it.
Any outlet that doesn't give you two orange lights only, don't use it until it's fixed.
If the outlet you've observed the tingle problem on is good - quarantine the item instead! Have it checked, and/or replace the power unit for it. Use the tester to validate the tingle... hold the tester in your hand and curl one finger round to touch one of the short pins; now hold it to the item and touch the long ground pin to the case where you felt the tingle. If one of the lights glows, that's potentially lethal and you have to stop using it in case someone gets hurt.
Jan 20, 2011 | Cameras
I''ve gotta small issue with an electrical outlet in my kitchen. I've got a GFI that is connected with two additional outlets as would be the norm. I was having a problem with the GFI popping every once in...
GFCI receptacles are polarized and connecting them correctly is critical. The hot wire should be black, blue, red, etc. The neutral should be white or natural gray. The ground should be green (if equipped).
Also, it's common to have other receptacles in a kitchen wired "downstream" of a GFCI so that if the GFCI trips or there is an issue with another non GFCI outlet, you're still protected.
Check all outlets in the kitchen and be sure they are wired correctly and in good shape. Unplug everything while you test. If the GFCI still trips, start looking for loose neutrals or bad ground wiring (or no ground) at the other receptacles since you said you already checked the breaker box.
A coffee maker can be a cuplrit that causes a GFCI to trip since it is a heating device and uses water, which can make them more susceptible to electrical problems. Check the microwave too (if equipped).
Jan 02, 2010 | IDEAL MCM TESTER GFI CIRCUIT
Outdoor Outlet Does Not Work
Your outdoor outlet(s) may already be ground faulted: often these outlets are fed from an existing GFCI outlet; check your bathroom(s) or kitchen for a GFCI receptacle. Use the tester he mentioned to see if it is live – be SURE to get a tester with the button on it that checks GFCI's as well – if the tester button kills the GFCI from any outlet on that circuit, you know the GFCI is working. Using the tester in your outdoor outlet verifies the GFCI AND the wiring to your outdoor outlet – something the GFCI's 'test' button can't do. ...Wilzard
Aug 08, 2009 | Rival S12T Electric Skillet
Like it has no power
hello, is it plugged into a gfi outlet ?in most newer kitchen with in the past 15 years most outlets are gfi in your kitchen,thay have a breaker build into the outlet that you can reset on the cover of the outlet also check your breaker on your main power breaker panel and try a different outlet to make sure the wiring for that outlet is'nt bad, also check the plug wires make sure there not loose if nothing then you'll have to take your blender apart to check the internal components.
Mar 31, 2009 | KitchenAid KP2671 Professional 6 Series...
My wiring fault light is on.
the input power is bad (outlet) it could mean your phase and neutral are backwards. What country are you in? If in USA home depot or lowes sells cheap outlet tester that let you know right away what wire is wrong
Alex
www.CAS411.com
Feb 22, 2009 | CyberPower 525SL (CPS525SL) UPS System
Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
Dec 27, 2008 | IDEAL MCM TESTER GFI CIRCUIT
Burners wont come on.
Hi , try to check the power outlet , posible recock the breaker , check also the piower cord test with continuity tester both end of cord (diconnect before you test ) switch on knob if tester response , try to connect to power outlet test the electric stove.
Feb 14, 2008 | Hotpoint RB757 Electric Kitchen Range
No power to the dvd player
Not sure but since you did not indicate wether this wall plug you are using is the same one you are plugging into when placeing on a stand.
I would say that if it is not the same one it would appear to be the only variable common.
Have someone check that outlet it might be wired wrong (if you don't have a tester ) ----(you can buy a line tester at home depot ,it plugs in to wall and has lights that display how plug is wired) -- I am thinking either you have no ground or polarity is backwards. If you have a VOM measure Nuetral to Ground it should be less than 5 VAC, higher than this is a problem.
Since most amps use low voltage switches internally any variation to the ground will vary the switching voltage.
If you are using the same outlet then the above still applies since when you unplug the poor ground may be shorting internally as you remove.
I would inspect the outlet you are using.
Dec 01, 2007 | Audio Players & Recorders
Electrical Supplies Logo
316 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
