Question about Compaq Presario R3000Z Notebook
My R3000 wont power up
Every time I shut my computer down I have the hardest time starting it back up. it use to take only a few tries of tapping or holding the power button, but not it takes forever. I started taking the top strip off so I had direct access to the button. This worked once, still after many tries. Any help would be much apprieciated.
  • 883 Answers
Sounds like the power button itself, down to the level where the contact happens, needs cleaning. I have cleaned these types of contacts many times. It is tedious and involves dismantling of the unit to access the switch contact area. Then clean both of the contacts with alcohol swab, then continue wiping with dry swabs until all alcohol is gone.
Posted on Nov 14, 2007
System worked for 2 hours then shut off came back on a few times
It shuts down to protect itself from overheating, looks like you tried to use it too much without sorting the problem out.
You can try and give it a good clean out. Google cleaning computers.
I usually use a small brush, my vaccum cleaner and sometimes an air duster
Jul 26, 2010 | Spherex Xbox 5.1 Surround Sound System...
Wont start up.
Have you tried booting windows into "Safe Mode"?
1. Power ON your computer.
2. After the Acer "splash screen" comes on, press the [F8] a few times (10 times or so, to "catch" the menu)
3. A menu will appear.
4. Select "Start Windows in the last known good configuration" (or something very close to that wording).
5. It may start for you now; and it will start normally from now on without pressing the [F8] key.
Let us know if thjis worked.
If not, what was the last thing that was done before it quit working right? Download? Install a program? Remove a program??
Sep 20, 2009 | Acer Aspire 5315 Notebook
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Presario r3000 shuts down
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
May 04, 2008 | Compaq Presario R3000 Notebook
Compaq pressario r3000
your some sys files are missing
repair your window.
check your ram , hdd, smps power cable ,earthing pro
check hitting event, check your bord dont touch the cabinet
Mar 24, 2008 | Compaq Presario R3000 Notebook
No display
Re- boot the computer, see if it will come back on again.
Go to start- click on log off -than click on restart it will shut down and back up again .
If this dont help try going to re-store - go to the calendar click only on 1 of the high lighted areas , Should put ya back on.
Nov 29, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000Z Notebook Logo
81 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
