F7 on my hot point. Washing machine - Washing Machines
  • Washing Mach... Master
  • 5,323 Answers
This error code indicates that the motor is having difficulty turning.
Are the shipping bolts removed?
All four (4) shipping bolts and the plastic spacers must be removed from the rear of the washer before you operate it. Each unit is shipped from the factory with four bolts, which are designed to secure the washer during shipping. Failure to remove all of the shipping bolts, and the four plastic spacers that are with them, can result in noise, vibration or error codes. See the Installation Instructions for details; find them by entering your model number in the search tool below.
Were you washing a very large load?
The washer may be overloaded for the cycle you are running. Remove a few items from the load. See the Cycle Guide in the Use and Care guide for loading suggestions for each cycle.
To remove the error display, press Power once. Then press Power again to restart the washer.
If pressing Power does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
Posted on May 15, 2015
2 Suggested Answers
beltronic205
  • 1467 Answers
SOURCE: My hot point washing machine makes a loud thumping
Could be drum bearings gone lots of play on inner drum....
Posted on Feb 17, 2010
F7 E1 codes for a whirlpool cabriolet wtw5600xw2
See http://www.appliancepartspros.com/diy-story-f7-e1-error-code-whirlpool-cabrio-washing-machine-diy559429.html should be a big help I also use www.repairclinic.com I am a natural Gas Appliance Tech and Heat Dryers any product hook to our natural gas line do other repair work to
Sep 02, 2016 | Whirlpool Washing Machines
My asko D5155 stops washing and flashes F7
LED L1+ L2/Fault code F7, Pumping out fault (machines with
pressure sensor)
Water not evacuated after 120 seconds pumping out. Program
interrupted.
Check: Drain pump, hoses, installation of drain hose, control unit and wiring.
Dado
Oct 06, 2015 | Asko Dishwashers
We have a hot point washer. That's washing ok spins ok some times. But once machines been turned off and I come to do another load. The machine is full of wTer why???
Maybe the cold/hot water inlet valve has a faulty seat or seal that is allowing water to leak thru to washer despite the valve being closed. Probably need to replace that valve. Look at some of these links on YouTube on repairing or diagnosing water problems:
hot point washer machine fills up with water with machine shut off YouTube
Mar 06, 2015 | Washing Machines
WE START A PROGRAMM TO WASH DISHES AND AFTER 2 MINUTES APPEARS 'F7' WE PRESS START LIKE RESET, WE CHANGE PROGRAMM BUT AFTER 2 MINUTES F7 APPEARS AGAIN
You have accidentally posted on the Washing Machine forum!
Best to re- post on the dishwasher forum and don't forget to say what make and model it is, please ;-0)
Thanks, John C
Mar 08, 2011 | Washing Machines
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool fault f7
how do i fix an f7 problem on my washing machine?
Jun 21, 2008 | Washing Machines
Bauknecht washing machine fault
Had the same problem myslef yesterday. Have rung whirlpool this morning and they advise that the code F7 refers to a short circuit.
May 27, 2008 | Washing Machines
Error code
Hi there, F7 = motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning. Thanks
Dec 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
