Question about Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL
How do I delete a download - Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL
How do I delete downloads?
Use application or go to remove application
May 11, 2016 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How do i delet a download on my nexus tablet
Open the Downloads app, from the list you can select and delete files using the trash can icon.
Feb 14, 2015 | Google Nexus 7
How do i delete downloads from tablet
It depends on your operating system. For instance, if you have an Android device, downloads are stored in the file system. Using an app like File Explorer, you navigate to the file folder called "Downloads" and press and hold on the file you want to delete. A menu pops up and you select Delete.
Feb 03, 2015 | Tablets & eReaders
How do you delete an unwanted download from a Digiland 7inch Android tablet?
Download ES file explorer. It is easyer to use. Similar to windows on computer. Than just search for "dovnload" file.
Dec 03, 2017 | Tablets & eReaders
How do I delete saved page apps from an ipad 3? I can dlete some but some won`t delete, they just blink and diapper on & off so I have to reboot my ipad?
Are the apps you're trying to delete ones you downloaded? Some apps were on your iPad when you bought it and those can't be deleted. Only those apps that you downloaded can be deleted from your home screens.
Jan 10, 2015 | Tablets & eReaders
How do I delete old downloads no longer needed
Usually the best way is to download a file manager application from your tablet's app store, navigate to the download directory inside that file manager application and use the application's delete command to delete unwanted files.
Oct 31, 2014 | Tablets & eReaders
How do I delete downloads on my trio G4 7 tablet
most likely go to settings and then look for applications go into this and find applicatiomn there should be a remove option.
Oct 28, 2014 | Tablets & eReaders
How do I delete downloads from nexus 7
I assume you are in the downloads app if so just touch and hold for short while it should then select the file and the delete button should (trash can) appear at the top of the screen.
Oct 27, 2014 | ASUS Google Nexus 7 Tablet
How do I delete downloads nexus 7
Install a file browser (I use ES File Explorer) and then just open the Download folder. Long press a file to select it, then press Delete button which appears bottom of screen
Game apps are stuck in download mode. How can I delete them? When they shake there is no x in the corner to delete them.
Depending on your iOS version, you will/will not have the option to delete it. Just let it finish downloading and then remove it. If it is not downloading, try restarting your device. Alternately, you could try a computer sync and see if it changes anything.
Nov 03, 2012 | Apple iPad 2 Wifi 16GB
Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL Logo
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
