Please resolve Error code 003-302
Switching on the machine XEROX MODEL 6030 WIDE FORMAT an error appears '003-302 please reboot' after rebooting the machine the error still remains SOLUTION Required
  • 2072 Answers
SOURCE: lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Posted on Dec 31, 2007
SOURCE: lsu error
LSU ERROR
Posted on Nov 22, 2008
SOURCE: CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Posted on Dec 14, 2008
  • 2072 Answers
SOURCE: xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
Posted on Mar 18, 2009
  • 110 Answers
SOURCE: Xerox Phaser 7400 displaying error code u60
Job Offset Home Position Sensor does not detect home position for the Job Offset Assembly.
Check the following for evidence of fault or
damage:
■ Home Position Sensor Actuator
■ SNS Harness
Is there any damage or misalignment?
parts that need to be changed if still no fixed.
Rear Sensor Board
Job Offset Assembly,
hope this helps.
Posted on Dec 17, 2009
Hi Shahab,
Have you looked inside the printer to see if you have any media or sensors blocked or torn media stuck inside.
Don't leave the lid open too long or your drum might get light shocked.
You need further investigation on this problem.
As the problem occurred several days ago I assume you might have it fixed by now.
Good Luck.
Apr 22, 2015 | Xerox Office Equipment & Supplies
Error code 010 398
The only suggestion I have would be to reboot the machine and try again. In a lot of cases any error codes AKA Fault Codes begining with 010- point to a major mechanical error.
Nothing specific sayiing so in my research, if a reboot doesn't bring the machine back up your next step would be to contact your Xerox service technician to go onsite to resolve.
If you're not holding a maintenance agreement on the WCP device
Check with the person you bought the device from to see if there is anything they can do to assist.
The WCP device you have is an older model and if you are experiencing problems with it on a regular bases you may want to contact Xerox and see if there is a possible upgrade strategy they can assist with and get you into a newer model with out breaking the bank so to speak. ????
I hope this helps.
Mar 10, 2015 | Xerox WorkCentre Pro 123/128 Printer
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
What is solution error code in xerox 6204 123-314
I am afraid you will have to call out a xerox service tech, he will have to reinstall the M\C siftware.
Jul 03, 2014 | Xerox 6R1238 6204 Wide Format Printer...
Please reboot printer (124-315)
How to reboot printer Xerox DocuPrint C4350 error code : printer (124-315)
Oct 03, 2011 | Samsung CLP 315 Laser Printer
How to reboot printer Xerox DocuPrint C4350 error code : 124-315
How to reboot printer Xerox DocuPrint C4350 error code : 009-383
Oct 24, 2010 | Xerox DocuPrint C4350 Laser Printer
Unknown error 009-391
Remove Cyan Cartridge. Trun Off the Machine.
Now Insert Cartridge, make it properly inserted.
Trun On the Machine And The Error Is Gone......
Try It
May 20, 2009 | Xerox Office Equipment & Supplies
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
Oct 19, 2008 | Xerox WorkCentre M123 Copier
Error Message - PLEASE REBOOT PRINTER (116-330)
Somewhere in the addressing there is an error.
You can call 1-800-821-2797 and ask for second level support. They can narrow down your problem.
116-XXX or 119_xxx codes normally have to do with addressing issues within the network.
Jul 24, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
