Question about Frigidaire PLD4375RFC Dishwasher
How can I fix my Frigidaire PLD4375RFC Dishwasher that leaks from bottom door even after new door gaskets 154576501 and 154701001.
Our 6 year old Frigidaire aka Electrolux (Model #: PLD4375RFC) dishwasher was leaking from the bottom of the door all over the place. I searched the net, and most of the answers recommend replacing the bottom door seal. The float does click when I pull up on it, and I don't see any cracks or obvious holes in either of the upper or lower spray arms. So I removed the door gasket, and it was a little worn at the edges, and corroded with deposits. I also removed the splash guards at the bottom of the door corners, and noticed they were split in half. I've already replaced the bottom door seal gasket (OEM Part: 154576501) AND the side flaps splash shields / guards (OEM Part #: 154701001), however it's STILL leaking. I think replacing the three gaskets helped a little, but now it's leaking mostly at the center intermittently depending on what it's doing. So I ran it again, and took off the kick plate and looked under it. It appears to be leaking from the hole where the electrical connector goes up the middle of the door in between some white Styrofoam. I took some videos. See below. You'll notice it's leaking a lot from that hole in the time-code 0:00-0:55, but right about 0:56 the machine changes it's tune and goes through another cycle of some sort and it stops ... https://youtu.be/ZKEkBN7I1SE In this clip a little later on, it changes it's tune again and goes through some other cycle or thing and the leak starts back up again at 0:12... https://youtu.be/ZPdBqa8iRMQ I have not replaced the tub gasket yet, but I don't want to throw unnecessary time and money at this thing if someone can identify this for sure, and send me a link to the correct part?
  • Frigidaire Master
  • 473 Answers
It sounds like you are fixing the wrong area. If water is coming down between the inner and outer door panel and following the wiring harness, the leak is inside the door. Either from the soap cup mounting or the rinse agent area which I think is the same unit on your model. There is a gasket behind that part. Also check the inner door if its plastic for any possible cracks.
Posted on Apr 23, 2015
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
I have a Frigidaire Gallaxy Series top loading washing machine, 4 years old that seems to be leaking from the bottom. Is this something I can fix myself? THANK YOU.
Before you buy a new $100 door gasket, pull out the soap dispenser tray and look inside the washer where it normally sits. If there is significant soap accumulation (even 3/8 inch), the water can become backed up and trickle down the washer front to the door bottom, making it look like a door leak. Fixed mine this way.
Jul 30, 2010 | Washing Machines
Leaking door
They had a big problem with this model leaking at the corners of the doors. I would replace the baffle (part# 154576501) and install a splash shield kit (part# 154701001, comes with instructions)
Apr 07, 2010 | Frigidaire PLD4375RFC Dishwasher
Some times it leaks water from the bottom of the door when it is running
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
fft
Dec 07, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigidaire dishwasher model pdl4375rfc2 serial# th80537081 door weaks aat lower right corner user less than 6 months is there a recall on this model
if unit is less than a year old . call for service 1-888-203-1389. this unit has a one yr. warranty from the manufacture. recalls are usually not given on appliances unless it is a safety issue. however i have repaired alot of these under warranty for your same complaint. their is a splash kit u can get that goes on each corner of the bottom of the inside of dishwasher that will stop it from leaking, roughly 10-20.00 dollars depending on who u purchase it from .hope this helps out.
Oct 06, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigidaire GLD2445RFS0 dishwasher has developed a door leak
Make sure the lower spray arm ends (there are 3 arms) are snapped together all the way. One of ours had come apart and was spraying water out the end of the one arm. It was enough to "spurt" water past the plastic gasket at the bottom of the door. I snapped the arm back together and BINGO. Free fix.
Sep 29, 2009 | Frigidaire Dishwashers
The dishwasher leaks through the front door. A gasket problem?
yes, this is an issue with this manufacturer.
you must remove the inner & outer door assembly.
the lower front tub has a front lip, the lip must be reformmed towards the rear,
then a seal that attatches to the inner door panel at the bottom must be replaced as its also
malformmed.
this fix works all the time.
*also remember dont use more than a teaspoon of gel or a tablespoon of powder
as this will cause too much suds and will spill over & out thue the front bottom of door.
nbcrca
Apr 11, 2009 | Frigidaire PLD4375RFC Dishwasher
Frigidaire dishwasher door won't close
with aa small thin screwdriver you can try to pry the "latch/catch "back to an open positon
Dec 17, 2008 | Frigidaire PLD4375RFC Dishwasher
Frigidaire dishwasher bottom door gasket replacement
thank you so much for this information it was a god send
Oct 07, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire PLD4375RFC Dishwasher Logo
149 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
