Question about GPX Audio Players & Recorders
I can't turn on the radio or install it - GPX Audio Players & Recorders
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
When I turn my head lights on my truck the radio won't work at all. It lights up and says camera on the screen but nothing works. When I turn off the lights my radio works fine. Why is that?
What is the source of power? Headlight circuit? . Installer boo boo? or possibly wiring is incorrect? Poor radio grounding possible Reccommend returning to installer before radio is damaged in order to preserve the warranty.
Jul 24, 2014 | Cars & Trucks
How to install axxess gmos 4 with aftermarket radio
Make sure you have connected the remote amp wire. This should be blue/white on the radio and connected to the blue/white on the GMOS-4.
Jul 03, 2014 | 2005 Chevrolet Avalanche
How to install echo board in a Galaxy 2517
  • This radio already has an echo board installed in it from the factory. On the bottom set of knobs, left side, over three knobs. That knob is your echo/delay knob. No need to install one. Just turn it on.
  • Hope this helps.
Nov 03, 2011 | Galaxy Radios DX-2517 CB Radio
Install Echo Board in Galaxy 2517
  • Hope this helps..
I installed new radio on honda civic 05 but it wont turn on. i tried to see if the old one still worked but it doest turn on either.
you need to check to see if your car has a radio lockout that won`t allow the radio to work unless you enter a code to unlock system.you will have to talk to the honda dealer for more information about this,or talk to a radio installer shop that deals with lockout systems for car radios
Mar 08, 2011 | 2005 Honda Civic
Need to install radio antenna on 1999 jaguar xk8
on the base of the antenna mast is a chrome nut (14mm?) unsrew that, then turn radio on , it will eject the guide cable. then insert the new cable, turn radio off and wait like 15sec then the motor will take in the new cable then put the chrome nut back on> thats it
Jul 29, 2008 | 1999 Jaguar XK8
94 bmw factory installed radio
hello . ok this happends after you try 3 times an incorrect radio code on the radio then you have to let the radio on for 60 min and the lock display will turn to code again if this happends constanly then the radio protection is bad and you need a new radio or you may take the radio to a radio fix place for them to take the protection part out
Jun 14, 2008 | 2003 BMW 325
524 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
