Question about Harman Kardon Audio Players & Recorders
Need images schematic diagram on how to connect wires to power on/off a 9 pin out harman kardon subwoofer HK395 using a switch DL series push botton
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
whitebirch
  • 433 Answers
SOURCE: i need connection instructions, please
http://www.harmankardon.com/product_support/SupportDetails.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=HK695&sjump=ps&ky=295752998DFB844994AFB5150B637833&#active
Here is the info you need to connect, manuals, troubleshooting, drivers...And instructions.
Please leave rating
Posted on May 03, 2009
  • 15 Answers
SOURCE: del harmon kardon hk395 9 pin plug
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Posted on Sep 30, 2009
Testimonial: "You confirmed the trace out that I had figured and gave me the confidence to jumper and get it working."
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
SOURCE: Harman kardon hk395 scematic
My wife has the camera in her car. Hope the attached diagram is not too crude. I bent sewing pins with the heads cut off. There is enough "spring" they don't fall out. Just leave space where they cross over.12_6_2011_1_40_52_am.jpgAlso I don't know if my numbers match the insie board or not.
Posted on Dec 06, 2011
The left speaker sometimes stops working. If I giggle the off/on switch on the right speaker it comes back on. What can I do to fix the problem?
you could try cleaning the switch.
could be just bad connections.
or just replace the switch.
or a loose connection.
it could be none of the above but worth checking.
Apr 08, 2016 | Dell Harman/kardon Hk395 Computer Speakers...
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
I have harman karden subwoofer but i dont have any
hmmm....does the subwoofer have any controls on it or are the controls on the speaker that came with the sub?
Jul 30, 2013 | Dell HK395 Computer Speakers
Del harmon kardon hk395 9 pin plug
Sep 14, 2009 | Dell HK395 Computer Speakers
Won't power up
  • Make sure all connections on the rear of Subwoofer are properly inserted in their connectors.
  • Check to see if LED illuminates on the front of right satellite speaker. If it is not illuminated, check the power connections.
  • Make sure power switch on satellite is turned on.
~gnomer
Jan 04, 2009 | Dell Dimension 4600 PC Desktop
Harman/Kardon HK395 speakers no power
there is actually a fuse in the subwoofer
Oct 21, 2008 | Dell HK395 Computer Speakers
HK395 Speakers/Subwoofer Cable
Jul 26, 2007 | Dell HK395 Computer Speakers
242 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
