Question about Casio Watches
How can I change the hands on my watch to get the right time?
Because unlike other watches, it doesn't display a screen with numbers, that can adjust, so I can only read the hands which I don't know how to adjust. It has only 3 buttons that are forward, reset and adjust. I've tried todo so as to fumbling with the buttons, so how can I adjust the hands? Sorry for all the 'adjusts'.
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Posted on Jan 16, 2008
Nickstar19
  • 417 Answers
SOURCE: Casio WR200M Watch.
you need to pull the pin out the thing take turns on the watch don't come right out tho one like 1mm
Posted on Jul 05, 2008
SOURCE: Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Posted on Dec 11, 2008
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Posted on Jul 05, 2009
How to adjust analog time in my g shock 20 bar
Press the "Adjust" button. It's usually the top-left button, slightly smaller than the rest. When you have successfully pressed the button, one of the numbers on the screen (generally the seconds) should begin to flash.
Choose which number you would like to change (hours, minutes, day, etc.) by using the "Mode" button on the bottom-right to cycle through each option on the main screen. You'll know when you have reached your target position because that number will flash.
Use the top-right button (usually labeled "Start/Stop," or sometimes "Light on/off") to change the number once you have highlighted the position you wish to change. When you have finished making the desired adjustments, press the "Adjust" button again to complete the process.
Use "Adjust" on any screen of your Casio G-Shock watch. To reach the watch's other screens, press "Mode" (bottom-right button). Most G-Shock watches have four screens total, including the main screen. On each screen, use the same process described above to make adjustments to the time (with the exception of the stopwatch screen, which does not keep time.)
Mar 15, 2017 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    My watch is stuck on military time somehow. I would like to know how to change it back to normal time. My watch is a Armitron Alarm/Chrono WR 165 sports watch. The number on the back is 45/6915. Thanks for...
    Welcome to Fixya,
    The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
    1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
    2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
    3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
    4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
    5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
    6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
    I hope this will help you.
    Thank you for usinf Fixya.
    Feb 21, 2011 | Watches
    Under the settings, limits, the limits on the max HR stop @ 100. I want to increase the setting on max hr but it stops @ 100 and then returns to 18. help [polar F4]
    Go into settings.
    Press the center button on the right hand side of the watch 1 time you will see settings watch time & date appear in the display.
    Press the bottom button on the right side of the watch1 time to get into the TRAINING SETTINGS FUNCTION.
    When you see TRAINING SETTINGS in the display press the center button on the right side of the watch once.
    You are in TRAINING SETTING mode.
    Press the bottm button on the right hand side of the watch 3 times until you see
    ZONE LIMITS displayed.
    When you see ZONE LIMITS displayed press the center button on the right side of the watch 1 time to enter into the ZONE LIMITS FUNCTION.
    Now, you should see the lower end heart rate limit number blinking.
    To adjust this number use the top button on the right hand side of the watch to increase this limit or lower button on the right hand side to decrese it.
    When you have it set where you want it press the center button 1 time to save that setting.
    Now you should see the upper limit number blinking.
    Follow the same steps to set the upper heart rate limit.
    When you have pressed the ceter button to set the upper limit you have completed setting the heart rates limits and the display should read: LIMITS SET!
    Feb 13, 2011 | Polar F4 Heart Rate Monitor Watch
    How do u set the time on a ga 100 g shock watch
    You hold down the A button for a few seconds until it beeps. The A button is the one that says 'adjust' on it and is at the top left hand corner of the watch face. After that you adjust your home city time by pressing the bottom right hand button. After you hit adjust again the watch face will rotate to the home city time. You can see your home city change in the bottom right hand lcd display. A description of the home city codes is in the manuals you can download from the site posted above
    Jan 10, 2011 | Casio G-Shock GW500A-1V Wrist Watch
    Changing from 24 hr system to 12 hr system
    • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
    • Make note of the hour if you don't have another clock handy
    • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
    • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
    • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
    Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
    Analogue hands don't correspode to digital clock
    Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
    1. Activate Crystal
    2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
    3. Push and hold (at least five seconds) the center crown
    4. Watch will beep and word (SYNCHRO) will appear in the display.
    5. Use the top + button to line up the minute hand right on the 12.
    6. Use the bottom – button to line up the hour hand right on the 12.
    7. When finished, press crown and you will go back to time.
    Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
    Fix the hands correct with the dejital
    1. Activate Crystal
    Nov 16, 2008 | Tissot T-Touch T33759851
    Cant remember how to change (hands) time on casio fishing gear
    Push the MODE (down left) bottom six times, you will see in your display HS then push the ADJUST bottom (up left) until your digital time start to flashing then push the SEARCH (down right) bottom the hands time will start to move, once you have set the time you want push the ADJUST bottom (up left) once and push the MODE (down left) once and you done.
    Ricardo DeLeon
    Nov 02, 2008 | Casio Fishing Gear Watch
    How to set watch
    I just set the time on mine with these instructions 1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
    2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours) then you can use the upper right hand button to navigate thru seconds, minutes and hours. Then you can change the time with the lower right hand button you can only change the time forward. I hope this helps !!!
    Apr 02, 2007 | Kenneth Cole RK5034 REACTION
    Watches Logo
    22 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Jimmy Accardi
    Are you a Casio Watch Expert? Answer questions, earn points and help others
