Question about Tablets & eReaders
How do I remove the system ui app and or to stop recording.
How do I get my acer tablet to work it says ui system has stopped
The problem is with the Google search engine not being compatible with the User Interface and an update failed
Delete your Google search and re-install the latest from the Google store.
If you still have problems you may wish to try the following at your own risk
Settings > More > Application Manager
change to All
Scroll down to the Google App and select it
select "Uninstall Updates"
If it asks to install a factory default, agree to that
Aug 05, 2017 | Acer Tablets & eReaders
My samsung galaxy 2 tablet system ui keeps on stop working how do i fix it
If you mean it shuts down then the battery is most likely failing, if you mean the programs stop running then try doing a memory dump, get rid of all the old data files you can. Transferring as much data to a SD memory card helps as well
Jan 24, 2017 | Samsung Tablets & eReaders
My tablet toshiba excite pure is saying Unfortunetly, sysyem UI has stopped. It goes off when i push ok and comes right back. How do i remove it?
Have you tried to wipe the cache partition
App data
Step 1 Press the "Menu" button and tap "Settings." Touch "Applications."
Step 2
Tap "Manage Applications," select the "All" tab and touch an application name.
Step 3
Touch the "Clear Data" button to wipe the app's saved data. Tap "Clear Cache" to remove any cached data for the app.
Phone Data
Step 1 Turn off your Android device. Reboot the phone or tablet into Recovery Mode. The process is specific to the device model. For the Motorola Droid, press and hold the "Power" button and the "X" key on the slideout keyboard. Release the "Power" button when the Motorola icon appears. Press the "Volume-up" and "Camera" buttons simultaneously to open the Recovery Console. To access Recovery Mode with the LG Ally, press and hold the "Power," "Home" and "Volume" buttons simultaneously.
Step 2
Press the "Volume-down" button to scroll to "Wipe Data/Factory Reset." Press the "Camera" button to select it.
Step 3
Scroll to and select "Wipe Cache Partition."
Step 4
Highlight and select "Reboot System Now."
Mar 03, 2015 | Toshiba Tablets & eReaders
Wt is [unfortunaly, system ui has stopped working
Your android is running on low memory. Transfer some files to sd card or delete unnecessary files. Also clear data of applications at 'Manage Applications' on your menu.
Nov 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My ZEKI android tablet keeps saying that unfortunately system UI has stopped working what do i do?
You can try pulling the battery then reinstall it and restart the unit. If that doesn't clear the problem go to settings, and then applications and look for UI and clear the cache and data. If that fails you can try to do a factory reset.
Nov 09, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
What does it mean system UI has stopped working on android trio 4.3" stealth?
This probably caused by an feature called 'Face Unlock'; either uninstall or disable it. Usually this done by Settings --> Apps --> (All -->) Face Unlock --> disable / uninstall.
Or when you actually really like that feature, make sure you've updated your phone and that Face Unlock app to the latest version.
PS: What it actually means is the Android System UI component has crashed (and will automatically restarted afterwards). You might see the statusbar at the top disappear and reappear after a few seconds as well ... (symptom).
Jun 27, 2014 | FUHU nabi Jr. 5" Capacitive Touch Android...
System ui has stopped m9100
You need to re-load the firmware, see here Support Firmware
Feb 08, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
On front screen its come up with "Unfortunately, system UI has stopped" report or ok. But it wont let you do any thing. I only just set it up last night. It wont even let you turn it off completely.
After researching about this online, it seems to be a software update issue. You can try to do a factory reset, and if you can get into apps, you can try downloading a "face lock" app, which seems to help as well. I hope that this helps!
Oct 28, 2013 | ASUS Google Nexus 7 Tablet
Tablets & eReaders Logo
121 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
