Question about Inverter Electronics - Others
Manuel for purewave silent 3.5kva pure sine wave inverter camping generator
4 Suggested Answers
  • 70 Answers
SOURCE: I have a pure sine wave power inverter 1000watt -
check the fuse on the unit
Posted on Jun 12, 2011
  • 1212 Answers
SOURCE: user's manual pure sine inverter
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
May or may not be identical to what your part number is but the general guidelines are the same.
If you are looking for the schematic, the manufacturers keep a tight lid on those to protect intellectual property as there are several ways to achieve the sinewave synthesis, and some are under patent or are under license.
If you understand the principles of a Class A audio amplifier, you should be able troubleshoot this type of inverter.
Posted on Jan 16, 2012
  • 5631 Answers
SOURCE: operator's manual prostar prc-p5000vasw vertical pure sine wave inverter
You should contat Prostar
http://www.prostarglobal.com/contact.php
Posted on Feb 07, 2015
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
Why is my pure sine wave keep blowing fuses?
please check if all attached connection are tight .Sometimes loose wire connection also causes fuse blow
Sep 15, 2014 | Electronics - Others
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
Having issues with my laptops when the AIMS 600W Pure Sine Inverter turned on. As soon as I exit the cab of the vehicle with the laptop the issues resolve themselves.
You will need to either mount the inverter further from where you are using the laptop or shield it enough to get the laptop out of the "arc" of the power generation.
Now the problem: The inverter does produce heat so you can't mount it in an unvented box.
You are dealing with the same problem as the high tension power lines, that has a radiation zone, and you either need to cut back the zone or move it further away.
If it the inverter was modified in any way, then they might not have gotten all the shields back correctly.
Sep 10, 2011 | Inverter Aims Pure Sine Wave Power...
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Electronics - Others Logo
129 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
