Machine suddenly stopped working. No power. - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check fuse also door inter lock
Posted on Apr 26, 2015
Treadmill (Nordictrack T9si) stopped suddenly... Power still being received by controller unit, but display doesn't stay lit so nothing functions
open up the control console and look for loose wires... if no loose wires are found, call CoreCentric Solutions and ask if they refurbish that control board... CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
Jul 06, 2016 | Exercise & Fitness
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
Machine will not turn on. It's plugged in, and other machines are working. Just suddenly stopped turning on?
Check the power cord to make sure it is fitting snuggly. Possibly change where ti plugs into the socket. If that does not work, it would appear that your machine has reached the end of its life. Usually it is cheaper to buy new than have the broke one repaired.
Mar 22, 2014 | Toshiba DVD/Video Cassette Recorder...
The machine stopped suddenly while it was in operation, i found the fuse in the power cable burnt, i replace the cable and tried to operate it again it worked for less than one sencond and it stopped...
Dear Sir:
You have a Short Circuit:
The short circuit only you can eliminate by usin VOM,
a) Isolate the power cable b) The main motor c) The power supply d) The main motor board e) The transformer.
You can also view my personal TIPS for helps.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Mar 08, 2012 | Nautilus T516 Treadmill
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
My computer suddenly quit working. The power just went off
The most common reasons for that are
1. power adaptor or battery isn't working - power problem. Some laptops require the battery to be in the machine even when it's running of the adaptor. If it runs out of 'juice' it will just go off suddenly.
2. overheating - It can get full of dust and dander and overheat the cpu which will also cause the machine to go off suddenly. It shuts off to protect the cpu from burning up. Sometimes if they get hot enough it can still take out the cpu... If the cpu fan stops working it will also overheat.
3. Control Panel - Power settings - check to see if there's a timer set to turn it off after so long etc.
Jul 08, 2011 | Fujitsu LifeBook A1110 Notebook
Canon mx330 printer error 5200
Try this: Press the resume button (or cancel).
If not, unplug the unit and plug it back in.
Or, try this: Open the lid so the printer moves the head to the center position and unplug the power cord. Remove the ink and head. Plug the machine back in and let it go through it's startup routine. When it's done, open the lid and reinstall the head/ink cartridges.
If this does not work, you may have a bad printhead. Printheads for Canons cost anywhere from $50 to over $100 depending on where you get them and what model the printer is.
WARNING If, during your testing, the machine suddenly dies completely (no power at all) do not purchase a new print head. Some Canon models have a bad type of failure where the printhead goes bad and shorts, which draws too much current from the main board causing the main board to blow. If you replace the printhead in a machine with a bad main board caused by this failure you will just blow the new printhead. Remember this only applies if your machine suddenly dies completely (no power at all).
Good luck.
Sep 24, 2010 | Office Equipment & Supplies
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
Jun 23, 2009 | Kenmore 204101 Single-Speed Blender
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
