Question about Fujitsu Heating & Cooling
Fujitsu asu9smlq not working.green light blink 2x in 10 secs.when turn on no cold air,only fan.outside unit don't come on.other room work fine and is hooked to same outside unit.What's the problem?
  • 4 Answers
Could u describe more detail when u saw led blink.... only green light or any led light else ??? Did u have error code from supplier !?
Posted on May 05, 2015
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Posted on Feb 15, 2007
  • 508 Answers
SOURCE: A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Posted on Jul 02, 2009
  • 288 Answers
SOURCE: HI, I have a Fujitsu ASTA18lCC. Fan working but
trying to get the compressor to operate. it could be a bad capacitor and the compressore wont start or maybe the compressor is burned up
Posted on Dec 15, 2009
Testimonial: "Thanks for the advice. It turned out that we had a blackout after the AC had started playing up. The blackout seems to have sorted out the problem.Thx"
  • 6 Answers
SOURCE: Ihave a fujitsu air conditioner
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Posted on Aug 13, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a fujitsu AOTR30LCT,
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Posted on Jan 24, 2011
Testimonial: "Thanks that worked called the fujitsu people and they replaced the faulty sensor"
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Jan 24, 2011 | Fujitsu Heating & Cooling
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
The compressor wont go on outside but the inside unit fan is working. it will not get cold.
This could be caused by so many issues,It would be best to call a Heating and air company for a service call.
May 31, 2009 | Fujitsu Heating & Cooling
No heat or cold?
is the inside unit in a closet or the attic. if in the attic there may be a float switch in the drain pan and you might have hit it causing the outside unit not to come on
Jan 04, 2009 | Fujitsu 24R1 Air Conditioner
FUJITSU SPLIT AIR REMOTE CONTROL PROBLEM
I had a similar problem with only fan air then the blinking lights, found out that mice had got into the circuit board and corroded some connections with their urine. I would try the above solution by turning the power off for ten sec first but remember that you have to leave it for a few minutes before you operate remote.
Aug 25, 2008 | Fujitsu 24C1 Air Conditioner
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Fujitsu split level
Check for errors like blinking indoor light if present. Reset the error by disconnecting power supply from the unit for 10 sec. and "on" the unit. If the error persist, some parts of the unit may be defective and need to replace. Like room air thermistor, coil thermistor in the indoor side or the relay board. Some safety device in the outdoor may give in, some outdoor parts may be defective. You need a qualified technician for the this problem.
May 17, 2008 | Fujitsu 24C1 Air Conditioner
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
Heating & Cooling Logo
146 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
