Question about Garden
I have put a new starter in my mower and I can not get it to turn over or start. I have put a new battery in the mowere and still nothing and a new main switch
    Sergeant:
  • 287 Answers
There is a relay or selonid that will engage the starter. Trace the wiring from the starter back to the relay or selonid and check to see what is not letting currant thru to starter.
Posted on Apr 22, 2015
Countax c600h mower won't start! New battery last week today tho turn key and nothing. Lights all on, brake and seat switches good and even tried taking 12v from battery direct to starter
If you put a new battery in last week and it won't turn over now then you either have a short across the battery or the generator on the tractor has gone bad. A lot of times dead or low batteries will have enough power to turn on the lights but not turn over the motor. Disconnect the battery leads and put an ohm meter across them with the ignition switch turned off. You should see a very very high resistance.
May 14, 2016 | Garden
My troy bilt starter want turn over
check for bad starter try jumping the starter if it starts replace bad relay if not replace bad starter or rebuild it new starter 80.00 dollars rebuid it 25.00 for brushes
Aug 30, 2014 | Garden
Turn key wont starts
yes there should be,its ether near starter solinoid or near battery
Jul 17, 2010 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
Mower sat over the winter. Turn key and nothing
Neither ... charge the battery first. New doesnt necessarily mean fully charged.
Charge it with a properly sized charger for 24 hours then check with a volt ohm meter.
May 01, 2010 | Garden
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My yard machine mower will not start it just just
sounds like the starter is locked up. but start by checking for loose connections
Nov 06, 2009 | Mtd 22" Yard Machine Push Mower
Engine wont turn over. too much compression. ehaust valve is opening. new starter and battery.take out plug and it will start. put back in , nothing
jtd ride on mower wont start will turn over a little but if i take the sparkplug out it will turn over no problem any ideas please
Jun 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Ride on mower mtd will not start
Use a jumper cable from the battery to the post on the starter where the wire from the solonoid connects, if it spools up normal its the cable to the starter motor, if it continues to turn slow remove the starter and clean up the places where the starter and engine case contact each other (to ensure a good ground). If none of these solutions correct the issue the starter could be dragging and need to be replaced.
May 26, 2009 | Mtd LAWN MOWER PART # 16998A DECK...
Turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
Put battery cables on wrong
For starters remove the battery and take it back to the store where you bought it and have them test it. Your solution may be to purchase another battery.
Apr 21, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Garden Logo
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
