What these the l and n stand for on the drain pump I cant remember wish one goes where
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
They can go eather way live neutral
Posted on Apr 26, 2015
Wont drain. cant hear the pump at all.
it would be cheaper to replace the d/w than to replace the drain pump. btu parts may be cheaper where yo live. but the pump is easy to change remove th drain hose from the bottom of the d/w then the plug that is attached to that unit and finaly the black rubber hose .write down model number and take the pump to the appliance store then reverse those steps. ps shop vac out any standing water and turn off power to d/w before service
Sep 29, 2013 | Maytag Dishwashers
Drain pipe in maytag washer lav3600aww
Best I remember there are two hoses that make up the drain, one goes from the tub to the pump the other goes from the pump to the house drain. You should have got a 6-8 foot section of corrigated drain pipe, this goes to the house, bends around on one end and into the house drain. the other end goes to the machine, you may have to lay down to attach it, I cant remember which side that pump is on, but it should be easily identified
Jan 12, 2013 | Maytag Washing Machines
Doesn't pump out olll the water after a cycle is complete
check drain hose for kinks,,check drain spout for connection blockage..if you cant listen for water going down drain in pump out cycles...remember most dishwasher are intentually not grounded
Aug 29, 2011 | KitchenAid Dishwashers
When it hits the final spin it makes a cruching noise and will not drain
Sounds like you have a bad drain pump. Usually the impeller will break off the pump shaft and spin freely inside the pump causing the noise. You will need to remove the pump and feel inside and see if the impeller is broken. Be sure to have a shop vac handy to drain the water from the unit before removing hoses. If its a frontload remember there is alot of standing water in between the tubs. Good Luck.
_MJ_
Dec 15, 2010 | Frigidaire Washing Machines
Krystal Clear Model 635 Pool Filter Pump 1500 Gph: I can not find my manual and I cant remember if th...
If you are talking about the plastic o-ring for your pool filter, it goes on the top, if I remember correctly.
May 17, 2010 | Intex Krystal Clear Model 635 Pool Filter...
When it goes through rinse cycle and starts to pump water out of the machine, the drain pipe fills up and overflows, then it will rapidly drain.
Usually there is a clog or restriction in the stand pipe(drain pipe) causing water to not drain away.....Suggest drain-O products.
If you have a very long drain or the stand pipe is not above the water level in the tub you will want some type of air gap to prevent siphoning.(siphon break kit)
good luck
Mar 14, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Changed water pump cant remember how belt goes
call or e-mail a car repair man and ask them to come to your house.It might cost a little money but your problem will be fixed.
Jun 15, 2009 | 2002 Ford Taurus
Water not draining
your chicken wish bone may have broken your drain pump- it may have prevented the impeller to spin while the motor was on-not good. you may want to consider changing the drain pump...
Mar 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Not draining completely
always going to be some water left inside your d/w, cant pump it all out as long as its under the grate and not filling entire floor of unit i wouldnt worry, before each cycle its going to dicharge standing water anyway
Feb 23, 2008 | Admiral 18 in. DWCA500AA Free-standing...
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
