Question about Kitchen Appliances - Others
Hi, I have a bread toaster and suddenly stop working! What do you think the problem and where to go in Dubai to fix it!!
hardrocko
  • 1476 Answers
SOURCE: The level of the toaster doesn't lock
I doubt if you can fix this without taking the unit apart. Usually it is not that difficult to remove the cover. Unplug the unit. Turn the toaster upside down and remove the screws holding the outside case on. The case usually slides off or by springing the bottom of the sides out you should be able to remove it. Once the cover is off it should be easy and obvious to fix the problem you described. When you have the unit secured reverse the order to assemble the unit and you should be back in business. Good luck.
Posted on Jul 19, 2006
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
  • 3 Answers
SOURCE: Bread toaster doesnt work
It could be the slide button connections or loose wires. You would have to take it apart to try and figure it out. It should be under warranty, though. I don't know if the box is required. You'll have to ask Back to Basics about that.
Posted on Oct 10, 2008
  • 1214 Answers
SOURCE: One side not working
Sounds like the element has failed. Not much you can do as even though they cost more than a 2 slice, parts availability is slim and none.
Posted on Jan 28, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
My 1950's toaster won't work anymore!! I love that toaster and I need it fixed!
This might be more useful, it shows fixing a burnt out heater wire, without resorting to new parts:
https://youtu.be/kXn1lTYCtGs
Feb 08, 2016 | Kitchen Appliances - Others
Why won't outside elements on both slots of 4 slice toaster come on?
The heater wire has opened. You should be able to see where the break in the wire is. Unfortunately there is no easy fix for that. New toaster time.
Jan 13, 2015 | Kitchen Appliances - Others
Right side lights on all buttons won't stop flashing and bread 'holder' stays closed
Hi! Try to unplug it from the electrical grid and to clean it inside the place where the bread goes, maybe there's a piece of bread stuck in there. I hope this will work! Have a nice day!
Sep 02, 2011 | Breville BTA840XL 4-Slice Toaster
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
I have Sunbeam 'Radiant Contol' TOASTERMATIC toaster. Must be 40 years old - and only recently stopped toasting. Is there anyone who might fix this - I think the radiant coils have burnt out. I live in...
There could a number of reasons why it has stopped working and depending on the problem it could be a simple fix but generally not. It is after all an old toaster as you realise. On the bottom is a model number AT-35 AT-40 or TA-J. It depends on what part is sentimental as the outside and ends and base can be transferred over to a working mechanism. I have a few of these toasters and think they are just great.
Sep 08, 2010 | Vacuums
Help with toaster. anyone there?
Well, I'm not a toaster pro, but I do make my fair share of toast.... I have an idea for you, I researched your product and couldn't find any specific help but try this:
Unplug your toaster, firmly hold the mechanism in the down position as far down as it will go, then turn the unit upside down, give it a good shake and flip the lever a bit. Reinvert, plug it in and see if you've got any improvement. (I think I learned this trick from the Andy Griffith show... you know old Emmett and the fix it shop) let me know if it worked! Sorry I can't be more help.
Dec 12, 2009 | Rowenta TL900015 2-Slice Toaster
Aug 04, 2009 | Kitchen Appliances - Others
Jan 28, 2009 | Waring WCT810 4-Slice Toaster
Only toasts part of bread
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Kitchen Appliances - Others Logo
130 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
