After a paper jam was fixed I got this code displayed and can not get rid of. How do I reset?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
Turn off
turn back on
if not working unplug
plug in and turn on
( reboot )
make sure all cartridges are set and all door closed
Posted on Apr 22, 2015
How to fix error code e04-01 after paper jam
Reset code in service mode F9/ram initialize/fuser reset/reset power
Aug 06, 2014 | Panasonic DP2000P Workio Spring located in...
Mine is displaying code error h5-01
this is 5 or more jam codes at once - likely hood is that the papers are jammed up on the fuser entrance on right hand side - if you remove the paper then go into service mode and use sim 13 to reset the code
Oct 15, 2013 | Sharp MX-2300N Color Copier
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
I had a paper jam. Got the paper out, but now
Some printers won't reset the jam condition until you open a specific door or cover -- even if you've gotten the jam out, they think it's still there until you open that cover. Try opening and closing all of the machines doors and access points, and even pull out the paper tray and push it back in.
If the jam condition still isn't cleared, turn the machine off and back on with the main power switch.
Jul 05, 2010 | Canon PC-940 Black and White Copier
How do you get rid of error light with no obvious paper jam on HL2140
the eror is probably caused by dust or paper slivers somewhere or a open door or the paper trat not being in right. Open everythign up look for dust and stuff then makre sure it is all closed and the tray in in right. It should then reset and the error goes out.
Usually this is from dust on sensors or a tiny sliver or paper jammed somewhere. Can be quite annoying to find and get rid of.
Mar 23, 2010 | Brother HL 2140 Laser Printer
Canon MP830 will not print Error code 5C10, And 5100 donaldbetty@juno.com
5C10 seems to indicate a paper jam. 5100 indicates either a paper jam or ink tanks not seated properly.
A) Paper jam: There is a rear cover on this model. Many paper jams cannot be seen from the outside. Sometimes even a scrap of paper from a previous jam will disrupt the paper path.
B) Follow your manual for installation of the ink tanks. Remove and replace the ink tanks carefully following the instructions.
C) Should these remedies not fix the problem, you can try resetting the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) If solution fails, your MP 830 may require repair
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ive got a pixma mx700 printer and im getting the 5c00 error how do i get rid of this
Error code 5C00 refers to possible paper jam or product needs reset or service.
It is possible that a previous paper jam has left a piece of paper inside the machine. If you cannot see any paper jammed at either input area, open the rear cover and look in there. Otherwise, you can try to reset the product:
Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on
If all of these suggestions fail, your MX700 may require repair service.
Dec 28, 2009 | Canon PIXMA MX700 All-In-One InkJet...
I was given a minolta photocopier and it has the code C 0500. Had a paper jam but have no idea what this code means.
That is a "low fuser heat" code. You can try to reset the code by using a paper clip and pressing the small "reset" button on the right side of the control panel. Hopefully it will get rid of that code for good... if not, You will need to have your fuser looked at (heat lamps, thermisters, etc.) Hope this helps.
Sep 17, 2009 | Minolta Office Equipment & Supplies
k24674
