Question about Radio Communications
Car Radio The radio cuts out if the volume is too high, or if I start using other electrical items in the car (electric windows, indicators, lights etc). Also there is an "AF" sign flashing on the radio You guys obviously don't offer support for free, so whats the catch? Tks sean Car radio is ecq mosfet 50 wx4 pioneer
  • 626 Answers
The FixYa site is all supported by volunteers answering the questions.
We are paid for the more technical problems, or people who want Immediate answers.
It sounds like the Stereo may have been wired to the car incorrectly.
If you have the model number, you can find the Users Manual on to check the wiring connections.
Best of Luck.
Posted on Nov 14, 2007
Blew a fuse installing radio. Now, van won't start???
Unfortunately some vehicles use the same fuse for ignition and non- critical electrical devices such as the cigarette lighter, interior lighting trunk opener solenoid etc... It could also be that the power supply wire (red) for the radio is double tapped to a fuse that is dedicated to any number of components and if it is interrupted (blown) the vehicle won't start or even crank. Another possibility is the vehicles computer detected a short or high amp draw and disabled the ignition to avoid fire or further electrical system damage.
The radio/player power line should be properly fuse protected for the highest amperage that the radio/player may draw when it is at maximum wattage, meaning CRANKED UP! It must be connected to the positive cable coming from the battery, safely away from the battery using a properly rated power terminal or power bar that is covered and sealed. It must be securely mounted, grounded and in an area that is clear of anything under the hood . This requires cutting the positive cable, putting connectors on each side of the cut cable and connecting them along with the player and power amplifier power line(s) to the new power terminal.
DO NOT CONNECT THE PLAYER LINE DIRECTLY TO THE BATTERY TERMINAL! The power line wiring for the player at max. volume MUST be of the correct amp rated gauge. You may also need to get a higher amp battery and a higher gauge battery cable to handle the power draw. It is also CRITICAL that every entertainment system component is SECURELY grounded with the right gauge ground wire to metal that is part of the vehicles frame. Failure to do this on a high amp system will toast your vehicles entire electrical system, (very costly mistake) also use dielectric grease on all electrical connections to maintain the integrity of all connections. I may have given you too much info, Good luck!
Oct 29, 2014 | 1993 Volkswagen Eurovan
Radio and cd,work perfectly,when i start engine,cd will not play?,radio will
This can be due to possible interferance from the car electrics, so check the voltage when the car is started and revd. If the voltage seems to go too high there is no regulation and the CD can cut off. Also the presence of statics of the alternator- if there is a failure of the rectifier/diodes/capacitor can cause this as the set works on pure DC when the car is OFF.
So use a voltage regulator on the outside- a -12 regulator to confirm and rectify the car electrics.
Jul 19, 2011 | Car Audio & Video
I have a 1998 lincoln towncar with a factory radio with the cd changer in back that didnt work? i started the car the radio came on for 3 min. then went out the lights on the radio started flashing on and...
Hello Amlatham312,
(which I highly recommend)... you can Register and
use BBB Industries FREE wiring diagrams and TECHNICAL SERVICE BULLETINS (TSBs)...
BBB Industries Premium Alternators Starters Power Steering Products
I believe you will find VERY LITTLE in common with the
WINDOWS & rear mount CD player...
Before I spent a lot of time chasing around individual
fuse circuits... Clean & service your main GROUND
and Battery Cables...
Base no concerns on the DRIVER's window
It is the most heavily used/abused switch
on EVERY Vehicle... everywhere:,1998,town+car,4.6l+v8,1305144,electrical-switch+&+relay,power+window+switch,4624
Example fuse kit
Amazon com Bussman NO 53 Buss Fuses ATC MAX Repair Kit Automotive
Hope this helps
Carnac the Magnificent
Sep 08, 2017 | 1998 Lincoln Town Car
When purchased, upon starting the car, the radio (manufacture model) volume knob would actually be turning down when you were turning the radio knob up, and it did the opposite if turning the knob up, the...
sounds like a serious electrical issue there hard to track down could be the computer staarting to go in car the radio could of been hooked up wrong causeing other stuff to short out what year is the car what kind of car
Dec 01, 2010 | Pontiac Grand Prix Cars & Trucks
Have used 1998 accord w/ cobra security. after installing a new stereo myself i'm having electrical problems: dash lights work but systems and gauges lights or indicators do not, no temp,...
ok - here is ur best bet - - - remove the radio - - ask a local radio sales and installer like - best buy - etc - - to see how much to install it - - then have them do it - better yet - put the old radio back in first - and see --
could be other things but for say 70.00 u get ur car right - electronics are today - best left to the pros
some of the common radios have built in amps - these amps can draw way too much power -- so let the pro get at it - worth the money in the long run
Dec 26, 2009 | 1998 Honda Accord
Radio cuts off and back on seems to be vol related
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
May 12, 2009 | Sony Car Audio & Video
Head light-Drivers side
Well it was the weird electrical situation but I got it fixed. For my premium service please email back and I will give you what fixed this non common problem.
Jan 26, 2009 | 2001 Dodge Caravan
Lincoln town car 1995 radio won't turn off
I have seen people remove the factory radio, cut the harness and splice it to an aftermarket headunit, then attempt to reattach the factory harness they cut off to install the OEM radio back in proir to sale. Try removing the radio and look to see if the wires have been tampered with. If so you need to reconnect the harness wire by wire and use crimp connectors not the twist and tape method. Otherwise the electrical system has been altered elsewhere. The ACC lead to the radio should power off the radio when you turn off the ignition no matter what unless the electrical system has been modified.
Nov 11, 2008 | 1995 Lincoln Town Car
2004 RX8 electric system
The radio screws holding the radio are not tight enough. to eliminate this problem remove the radio and adjust the pressure screw in the rear of the radio so it comes out farther>. if the radio is not far enough in the compartment to push in that button the radio controls will not work
Jun 12, 2008 | 2004 Mazda RX-8
Radio Communications Logo
111 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
