Question about Frigidaire Dryers
MY FRIGIDAIRE DRYER STOPS AND THE DISPLAY READS E16
  • Official Brand Answer
  • 4,342 Answers
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Posted on Apr 29, 2015
3 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: I have a brand new
If this is a brand new unit, it will come with a factory warranty. ANY work done on the unit by an unauthorized servicer will VOID the warranty on the whole unit. I would advise contacting the selling dealer and have them send out an authorized servicer at no charge to you. If they are unwilling to help, post me back and I can find you an authorized servicer near you.
If this advice helped fix your problem, please rate my advice on the strength of help that I provided.
Thank you,
Dave E. (Illeagle)
Posted on Jun 17, 2008
SOURCE: LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Posted on Jul 16, 2009
E16 ON DISPLAY FLASHING
The e16 error code indicates that there is a problem with the machines door lock.
Mar 04, 2016 | Bosch Washing Machines
We have a new Frigidaire FASG7074NR2. It stopped at the beginning of the cycle and read door open. The door was not open. We tried opening and firmly closing the door and unplugging but it still reads door...
Good Morning Frances,
I understand that your new Frigidaire dryer, model# FASG7074NR2, stops at the beginning of the cycle and states that the door is open. I also see that opening the door firmly, closing the door firmly, and unplugging your appliance, the display still reads "Door Open", and will not run. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and determine why it is stating "Door Open". I hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Fasg7074Lr 7.0 Cu Ft Gas Dryer
My hover washing machine stops and it reeds e16
As you have not told us the model, on some Hoovers 'E16' reads as 'water heater element insulation fault' and will need a service call. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 18, 2011 | Washing Machines
My dryer is not getting hot. After 10-15 minutes of running, it stops and all of the lights on the control panal flash. The screen that usually reads the time reads "Aj"
it is more then likely the heating element, here is a website to assist you, Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 06, 2011 | Frigidaire Electric Dryer
Dryer works for 20 sec and then beeps 6 times and stops
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134420600es.pdf
this is a web site with you manuals. check it out and see if this does not get you started.
http://www.frigidaire.com/manuals
here is another with more manuals.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efs.pdf
this one reads the error codes.
Good luck.
May 01, 2010 | Frigidaire FEQ1442ES Electric Dryer
My Frigidaire AEQ6700FS electric dryer starts normally but only runs for about 30 seconds, then stops. The lights and display stay on, and the 3 lights at the far right blink all at once. There is no error...
try the timed dry setting there may be a problem with the moisture sensor bar.
you should also check the thermal fuses inside the dryer.there maybe one that is weak or bad
Mar 14, 2010 | Frigidaire AEQ6700FS Dryer
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Replaced heating element in dryer. will not run.
You have a bad (thermal limiter). It's like a fuse one time shot, it stops all of the control power to the dryer. Try testing it with the dryer unplug use a ohm meter across the leads. It should read some type of a reading, if it reads OL it's burn out.
Jan 13, 2009 | Frigidaire GLER341A Electric Dryer
My camera won't turn to the photo setting, and reads E16
same problem. mine turns on and i can review the pictures but as for taking videos and pictures, it reads e16.......mine was left in the rain though and these events occurred after one week of drying
Jul 10, 2008 | Cameras
I have a brand new Frigidaire FTF5000h dryer that starts, runs for a few minutes and then stops. When I check on it, all the lights are flashing and instead of a time, the display reads "ad"....
Thank you,
Dave E. (Illeagle)
Jun 17, 2008 | Frigidaire Dryers
Dryers Logo
266 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
